First - welcome, glad you found the site
Was working on a list fro the FAQ sections but guess we can start it here first
Front steering - Center link, strut rods, idler arm, pittman arm, tie rods and spindles were a somewhat dark heat treated bare steel with brighter machined surfaces where indicated.
Tie rod adjusters- were closer to a bare steel with nuts, washers and nuts a darker tone
Upper A arms- were bare steel (with machine and stretch marks from their forming. Hardened steel inner shaft and end caps (or what ever the formal term is)
Lower A arms- same as uppers but when completed they were dipped in semigloss black (inner end outward) up to about the strut rod attachment points
Front shock saddle.- Bare steel finish, no rubber pad for spring nor hole to retain them. Center shaft and bolts darker heat treated look
Front shocks- painted/sprayed semigloss black
Steering box - cast iron main body with brighter machined surfaces at the column end. Zinc or bare steel end cap and natural bare metal cover. Cover retaining bolts I've found were a bit dark.
Front Coil springs -
Remember the safety wire that uses two separate pieces of wires for each spindle to assure that the caliper bolts do not loosen. (believe a search here will help you find some original examples of the routing and wrapping)
Sure Bob will be by soon to double check my work
He's always a welcomed help
Well that is a start - you asked for a long list. Might want to go through your specific needs
