Author Topic: Gas Filler Rubber Tube  (Read 624 times)
Offline kkupec02
« on: December 18, 2021, 09:11:49 AM »
When you install the rubber tube to connect the gas tank neck to the metal gas filler tube, does the red stripe have to be in any particular spot like 5 o"clock, 12 o'clock?
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
Re: Gas Filler Rubber Tube
« Reply #1 on: December 18, 2021, 12:59:34 PM »
I have seen no stripe,white stripe ,red stripe . Red stripe being the least. I believe the stripe did not have a alignment purpose in this case so it didn't matter .From a workmanship or appearance standpoint you may want a 6 or 12 index. Just my opinion.
« Reply #2 on: December 18, 2021, 02:19:01 PM »
I believe the stripe did not have a alignment purpose in this case so it didn't matter. From a workmanship or appearance standpoint you may want a 6 or 12 index. Just my opinion.
The assembly line worker would most likely take advantage of any curvature of the hose as a guide to installation. If any colored line was present and it followed the curvature, it may have been coincidental.
