Author Topic: correct nose cone for 351W starter 4 speed  (Read 1544 times)
Offline SCJSTU
« on: December 17, 2021, 01:15:21 PM »
did a search and nothing popped up
anyone got a part number?
car built Jan 1969
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
Re: correct nose cone for 351W starter 4 speed
« Reply #1 on: December 17, 2021, 08:38:16 PM »
car built Jan 1969
That is a very hard to find nose cone compared to the common automatic version. I don't have a part number to order from because that is basically useless in this case. I have gotten used to identifying them from the unique physical appearance since the the numbers are typically covered with dirt and grease.  The engineering number that is cast into the part that I have seen frequently is C5TF-11131-A. There is also a DOOF-11131-B that looks the same. Obviously the DOOF -B would be after the fact however the outward appearance once mount is identical in all aspects. There are probably others but like I said I am mainly concerned with what the nose looks like once mounted . I consequently haven't paid a lot attention to the various numbers. I have only have been concerned with what it looks like from a judging standpoint when I look under the car. Also keep in mind that starting in 1968 production that a wrong nose cone can cause flywheel/flexplate engagement problems.
Offline SCJSTU
« Reply #2 on: December 21, 2021, 02:06:56 PM »
looks like I needed the long nose cone........short one was on it and would just free spin most the time......long cone kicks it off every time.....thanks
Offline agwinged
« Reply #3 on: February 01, 2024, 06:54:59 PM »
Is there a list of nose cones stamped numbers and application someplace.  I've looked through my Ford MPC and couldn't find one.
« Reply #4 on: February 01, 2024, 07:50:01 PM »
Pretty simple as far as application on the Mustang. The two ear noses cones regardless of if auto or manual were all the same 65-67 . Starting in 68 there was a change in teeth on the flywheel to 164 which triggered a change in the manual trans starter nose cone to be the wider variety compared to the  narrow one used on all automatic versions 65-70 . If you want the original look stay away from any marked that start with D1,D2 etc. Those starter nose cones were improved with strength gussets in the casting that are different looking on the inside and outside of the part.
Offline Wills70
« Reply #5 on: February 06, 2024, 07:28:21 PM »
Some information I have saved
