Author Topic: Need suspension paint markings for SJ 68 GT/CS 289 PS PDB 3 speed  (Read 536 times)
Offline jtboss302
I've checked a bunch of threads but they all seem to be for big block cars and I'm sure the paint markings on the springs are different Thanks in advance and Any help appreciated    Here's what I found so far
For steering the following components got a somewhat strong yellow strip applied with a approx 1" brush to the
- Center link between the idler arm and passenger tie rod attachment points
- Idler arm - the arm between the two ends/attachment points
- Pittman arm - again between the two ends
Heres what I still need:
- Paint markings for the front and rear springs?
- Paint marks on the steering box?
- What is the proper finish for the strut rod bushings?
Offline jtboss302
Re: Need suspension paint markings for SJ 68 GT/CS 289 PS PDB 3 speed
« Reply #1 on: December 13, 2021, 12:43:13 PM »
The build date was 2 Apr 1968
« Reply #2 on: December 13, 2021, 05:47:21 PM »
Often not an inch wide but you have the location correct for a typical application. See the bottom note
Strut rod bushings are just natural rubber
I suggest you look at the examples of this details and at least two of the steering related markings in the Unrestored Picture thread in that section.
Reply #14 under the title Late 68 San Jose C Code Coupe
« Reply #3 on: December 13, 2021, 06:21:57 PM »
As a reminder for all (standard boiler plate warning :) Paint marks will not make a non-factory looking part more original nor will the usage of paint marks make up for a non-factory finish or other detail
For a
Apr 2 68 completed GT/CS 289 with PS, PDB, and a 3 speed with a VIN likely around 8R01C155xxx
Here's what I still need:
Taken from C code buildsheets like your vehicle built before and after your car
Front springs - One red and one yellow stripe
Rear springs - One silver stripe
Shocks - Red daub on each
Driveline identification - Three stripes - Lavender, Dark green, light green
As for the steering box consider that the top of the steering box was likely covered, from the top and dripping down the sides, during a "black out" process where a worker passed a wide brush with black paint over the top surface. This process could cover the areas where the paint marks could have been applied fully  or partially. Examples of 68 San Jose built cars with the black out can be seen in that thread I mentioned in the last post and in the picture below.
With that said as far as 68 examples I can offer the following  based on what I've seen and documented.
In these examples you can make out a large paint daub or swipe under the black out paint where it has chipped or worn off
Also often find during this period a white daub of paint over the main case and plug on the lower front end (as the box is installed in the car)
Examples and description of general paint marks, usage and applications is available in an article posted in the Library section of the site
Offline jtboss302
« Reply #4 on: December 18, 2021, 12:54:27 AM »
Hi Jeff, thanks again for the info, the pic thread of the low mileage SJ couple was good to see.  Your info is most helpful...as always.  Have a Merry Christmas
