Author Topic: Ignition Keys and Buildsheets?  (Read 12485 times)
Offline C6ZZGT
Re: Ignition Keys and Buildsheets?
« Reply #30 on: February 22, 2022, 12:43:32 AM »
my code is just 2 digit "96". Could that be possible for early July 64?
The code will be FE96 , not sure if that is ign or trunk so you should have another for the other key . Not sure when they changed to the FA and FB coded keys.
Brian
66 GT Coupe 6R07A143871 owned since 1983
40+ yr parts man , over 25 with Ford.
« Reply #31 on: February 22, 2022, 12:17:33 PM »
Single cut keys from 1952-1964.
'FE' identifies the key, which is door and ignition. So is 'FL'.
'FN' and 'FZ' are keys for glove box and trunk.
96 indicates that the cutter code is 13231.
« Reply #32 on: February 22, 2022, 12:25:06 PM »
West Coast Classic apparently has access to the code books ;)
"1" is the shallowest cut and a "5" would be the deepest cut that could be used SO, in this example, a 1,3,2,3,1 cut pattern doesn't exceed 2-cut depths (side-by-side), allowing the tumblers to flow freely across the key cuts. UNLIKELY to find a 1-cut depth next to a 4-cut depth...the key would bind up going in/out.
« Last Edit: February 22, 2022, 12:31:25 PM by 67gtasanjose »
« Reply #33 on: February 22, 2022, 02:32:56 PM »
Not true.  Code 465. Cut code is 14141. On a single cut key.
Double cuts? key code of 0313 - The cut code for that one is 15151. Code 1550, the cut code is 51515.
« Reply #34 on: February 22, 2022, 04:32:16 PM »
Ooof! Seems rather steep!
Offline C6ZZGT
« Reply #35 on: March 06, 2022, 08:00:02 PM »
Turns out that I do have code books for the early stuff and yes those will jump more than 2 . The newer 8 and 10 cut codes don`t do that.
Brian
Offline 64.5 Fun
« Reply #36 on: April 02, 2024, 03:51:50 PM »
Hi all,
New member here, as of today.
We got a 64 1/2 Coupe from her dad's estate. We searched as best as we could but couldn't find the trunk key. We have the ignition key and I'll check it to make sure it works the doors.
My question is if anyone here could help me get the trunk key code (maybe it's a good Idea to get the ignition key code as well....)? I learned a lot reading through this thread! This car doesn't have a locking glove box. And I'm not sure if I could 'break' into the trunk somehow.
Any information that would help on this would be greatly appreciated!
« Reply #37 on: April 02, 2024, 05:22:14 PM »
Hi all,
First, welcome.
To answer your question, go to a locksmith. I had the same "no key for my trunk" problem years back for a newly acquired used car. A locksmith got the trunk open, lock cylinder out, new keys made and cylinder reinstalled in 30 minutes (he answered the phone a couple of times too).
Offline 64.5 Fun
« Reply #38 on: April 02, 2024, 10:07:24 PM »
First, welcome.
Thanks for the welcome. We are having troubles here locally having a knowledgeable locksmith. But it has got me to learn a lot about locks.....
I made good progress this evening. I had already planned on opening it myself (if I could figure out how to) and handing the cylinder to the locksmith. Well, you can get into the trunk by pulling the rear seat! Then I decided to try the keys we found again. He had changed the ignition key switch so I figured out we have at least 3 keys to operate this car. (I say it this way because I can't get the passenger door lock to work.  Yet)
I will tell you all: You NEED to get a can of Houdini 4-Way Lock Lubricant.  It works better on locks than anything I've ever tried.  It often runs $20 or more for a 11 Oz. aerosol, but it's very worth it!  Keys and Locks work better than new!
« Reply #39 on: July 24, 2024, 08:31:47 AM »
The key codes were also recorded in the upper rh area of the  pre-delivery sheet along with new owner info.
Offline jet hardtop
  • I drive my car 7 mpg or less
« Reply #40 on: January 02, 2025, 01:29:42 PM »
I have keys for my car with round tag that says record and detach FA0756 on it. Ownership since 1979 of 1969 Mustang GT 9F01Q ******
Hardtop GT deluxe 428 CJ 4 speed  traction lok  Black Jade Metallic bucket console one of one
« Reply #41 on: January 02, 2025, 06:49:33 PM »
Welcome to the site. Hope you find the site useful and fulfilling in your concours related endeavours. Now that your a member all kinds of new sections are available to you so take your time and explore
Again welcome
