Author Topic: 67 GT500 dual point AUTOLITE distributor C5AF 12127 E ?  (Read 4022 times)
Re: 67 GT500 dual point AUTOLITE distributor C5AF 12127 E ?
« Reply #30 on: December 15, 2021, 07:00:12 PM »
Quote from: RoyceP link=topic=25734.msg159855#msg159855 date=1639598558
This is an original one from a 1967 - is it thick or thin?
[/quote
For comparison so each of us could evaluate. My earlier comments related to thin was from another source don't know from where and how they drew their conclusion.
Upper left -you can barely make out the printing. Not easy to get a picture without taking things apart. Late 67 San Jose car
Royce yours is in the upper right
Bottom two are current reproductions. One from each of the two major makers
« Reply #31 on: December 15, 2021, 10:44:56 PM »
Thanks Jeff but I still don't know except that I know from your pictures the reproductions are way off from the original in terms of the material appearance. Those look like styrene plastic while the original seems to be Bakelite.
« Reply #32 on: December 18, 2021, 06:31:55 PM »
Don't disagree. Unfortunately like many reproductions they appear to fall short. Sometimes it's due to the lack of the original material, cost factors or what the maker expects to be a price point the majority of buyers will accept
Leaves some of us to seek out originals and original issue NOS parts
Such a common subject
Offline Kyle Zammit
« Reply #33 on: December 22, 2021, 10:24:40 AM »
Thanks that would make it a very early example and the reason it may have either IMHO internals
As for the cap it appears, based on what I could turn up, that if it did have an Autolite cap it would have been the thin letter version.
There is a reproduction of that cap available
Jeff,
So it need's to be (Fomoco points) (Fomoco rotor) (Fomoco condenser) (Fomoco dist wire) and Autolite cap?
Is this would be correct assembly line please?
Thanks.
Offline Kyle Zammit
« Reply #34 on: December 22, 2021, 10:42:27 AM »
I am seeing that there are different shape dist wire grommets.
Witch one is the assembly line one please?
« Reply #35 on: December 22, 2021, 03:09:39 PM »
As mentioned in reply #12 I believe at this point it could be either FoMoCo or Autolite or a mix given when your dist was assembled
Offline Kyle Zammit
« Reply #36 on: December 22, 2021, 04:17:30 PM »
Ok thanks a lot Jeff.
Offline Kyle Zammit
« Reply #37 on: December 22, 2021, 04:25:45 PM »
My last two questions,The distributor cam what degree is common for an early 67 Shelby GT500 please?
There are different degree cams.
Last question the dist wire are a lot of types.
Which one is the correct assembly line for my car please?
Thanks Kyle.
