Author Topic: 1969 B2 Water Pump  (Read 2581 times)
Offline Gcodecowboy
1969 B2 Water Pump
« on: November 23, 2021, 01:53:55 AM »
I have a June 27th 1969 Boss 302 build. Were the 1969 B2 Water Pumps date coded? If so, what casting numbers and date codes should I be looking for? I see there are different types of water pumps on eBay with the same casting number C8OE-D. Some have date codes and others do not.
« Last Edit: November 23, 2021, 10:19:58 AM by Gcodecowboy »
06/27/1969 Boss 302
Offline 69BOSS302
Re: 1969 B2 Water Pump
« Reply #1 on: December 12, 2021, 02:44:33 PM »
I think the correct number for a 69 is a C8OE-D. There again, not specific for a boss except for the 6 vein rotor.
Not too sure about the date codes.
See if this helps, and you can always call Jack Brooks at Dead Nuts On too.
https://www.deadnutson.com/1969-boss-302-water-pump-rebuild-service-return-shipping/
Philip
69 BOSS 302
9F02G198123
May 23, 1969 - Dearborn
« Reply #2 on: December 12, 2021, 04:14:08 PM »
Agree that the part carried the C8OE-D engineering number on the tip of the pump behind the pulley flange. No date codes it appears only a possible cast number.
As mentioned the main body is somewhat generic and shared with allot of other engines - just the impeller difference
