Author Topic: 65 Dearborn Tie Down Brackets  (Read 1103 times)
« on: November 20, 2021, 05:49:09 PM »
Choose to start a new more focused thread since the other one we have was not plant focused
Recently member 67gta289, posted a "guess the car thread" and even though the car was apparently a non-dual exhaust 64 1/2 the car had what is commonly referred to as dual exhaust rear tie downs.
https://www.concoursmustang.com/forum/index.php?topic=25684.0
Today going through, labeling and resizing some new pictures and adding them to my collection I came across another example of the same practice. In this case a 65 C code car built late in the production year - 5F09C7861xx. Unfortunately the angle does not show us if there was a third bolt used to attach the bracket to the frame
So I guess its time for a deeper dive and ask that others take a look or be on the look out for 65 Dearborn examples to see if we can figure out if these are oddities or standard practice during 65 at Dearborn
« Last Edit: November 20, 2021, 05:53:56 PM by J_Speegle »
Offline Countrysquire
    • Houston Vapor Blasting
Re: 65 Dearborn Tie Down Brackets
« Reply #1 on: December 09, 2022, 12:34:41 PM »
My 6/20/64 Dearborn D code car has the three bolt ?dual exhaust? tie downs.
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com/
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
Offline Carters
« Reply #2 on: February 21, 2023, 09:16:19 PM »
My Dearborn C-code build date 2/26/65 has the three bolts in the tie down.
Offline Carters
« Reply #3 on: February 21, 2023, 09:17:11 PM »
And the tie down on the other side.  Hope these help.
