Author Topic: 66 289 2bb, carb spring  (Read 610 times)
Offline KevinK
« on: November 15, 2021, 08:22:51 PM »
Can someone provide picture of 289 2bbl carb throttle return spring and any support post for the other end. My buddy had his carb replaced by a professional shop and it was a jacked up afterwards.
-New carb is probably a made in China copy.
-Choke spring not in the slot. Choke jammed on when hot.
-New carb had an electric choke but no wire to it. We converted it back to the old style.
-Heater hose not routed to the choke but it had a bracket to hold it.
-Vac advance was connected to the bowel vent.
-Heater hoses routed backwards.
Lastly, is there any type of auto transmission down shifting linkage at the carb on the 66?
66 coupe, SJ, 289, 2BBL, PS, TE (removed), automatic.
MCA #33800, Gold Card 3rd Gen
BAMA Member
Re: 66 289 2bb, carb spring
« Reply #1 on: November 16, 2021, 12:35:32 AM »
Attached to a small L shaped bracket attached to the DS rear carb mount stud. Shown in top pictures just barely.
Other end attaches at the bend of the throttle arm between the carb and the bell crank. Visible in the lower picture
Add a few more pictures to the unrestored picture thread of this car in that section if you want to see more general carb pictures. Late C code automatic non-Thermactor San Jose example
Have more if you need more details
No its built in the throttle bell crank attached to the firewall
« Reply #2 on: November 16, 2021, 12:50:28 AM »
Try this forums library, topic "ConcoursMustang.com Official 66 Mustang Article List" and use the "65-72 edition of Ford Car Parts" - aka MPC. Illustrated section 95 page 3 shows a drawing of the carburetor. Illustrated section 97 page 5 shows 66 linkages BUT IT IS WRONG. Use the 67 289 linkage drawing in section 97 page 13.
On the underside of the carb, there is a casting number, and there should be a Ford logo as well.
See the carb drawing,  sect 95 page 3.
Now that's a new one. There's a threaded port on the RH (driver's) side base where the line to the distributor goes.
There are two different routing drawings for this. I prefer to take the hot water from the fitting on the intake manifold,  route that hose to the holder on the thermostatic choke, then to the lower fitting on the heater core (it's inside the car) against the fire wall, then the top fitting goes from the port on the water pump. That way you get the choke heated faster. The service manual routes the water from the heater to the choke, which takes longer to heat. Make sure the hot water goes in the bottom heater fitting. That will force any air bubbles out of the heater core.
No. See the picture for the 67 setup. The downshift arm is welded to the bent up gas pedal rod.
Offline KevinK
« Reply #3 on: November 16, 2021, 04:16:25 AM »
Thanks guys. The info was very helpful.
There was not much in the 67 Engine assembly manual.
BAMA Member
