Author Topic: GT Fog Lamp Wiring Routing  (Read 1004 times)
Offline 65,66,67UNRESTORED
« on: November 09, 2021, 06:29:42 PM »
Could someone tell me the correct routing for the Fog Lamp Wiring harness and where the ground wire attaches ? We lost the pictures we took before disassembling the car.  Thank You!
65 Fastback unrestored survivor Ivy Green, Black Interior, C code, 4speed, A/C
65 K Fastback unrestored survivor Ivy Green, Palomino Interior
65 Coupe unrestored Caspian Blue, White Vinyl Top, Blue Interior, K code
66 Convertible unrestored survivor Raven Black, Red Deluxe Interior, C code, A/C
Re: GT Fog Lamp Wiring Routing
« Reply #1 on: November 09, 2021, 08:15:20 PM »
Are you referring to the front main harness that contains the fog light wiring?  If so I would suggest buying a 68 electrical assembly manual there are many different wire holders and attach points. The grounds attach under the lower voltage regulator.
« Reply #2 on: November 10, 2021, 12:27:29 AM »
Yup. Get the whole 68 set.
« Reply #3 on: November 10, 2021, 07:49:28 PM »
just the routing between the the fog lamps is all.
Offline Keith Stem
« Reply #4 on: November 12, 2021, 02:43:09 PM »
Both of the Blue Fog Light connectors mate with the blue connectors that should be coming out of the wiring harness that is routed through the lower left side of the radiator support. the wiring from the Fog Light is attached to the grill support with a plastic clip. The left and right sides are a mirror image. The attached photo is the best shot I could get of the left side.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #5 on: October 30, 2023, 03:12:28 AM »
Was looking thru some posts on original fog lamp wiring at the grill and wanted to included photos here of what the original clips look like.  Had to learn the hard way that Ford service parts (fog lamp assemblies) have some differences with the clips they include being one of them.  These are the clips that hold the wiring to the grill support brackets.  Should be one on each side - one per fog light.  This one is a Dearborn CobraJet car built July 18 1968.
Comparison here:
2023-10-29_22-54-32 by Marcus Anghel, on Flickr
2023-10-29_22-55-53 by Marcus Anghel, on Flickr
« Last Edit: October 31, 2023, 12:15:27 PM by J_Speegle »
Marcus Anghel
www.anghelrestorations.com
« Reply #6 on: October 31, 2023, 02:07:40 AM »
Was looking thru some posts on original fog lamp wiring at the grill and wanted to included photos here of what the original clips look like.  Had to learn the hard way that Ford service parts (fog lamp assemblies) have some differences with the clips they include being one of them.  These are the clips that hold the wiring to the grill support brackets.  Should be one on each side - one per fog light. ...
Marcus for the record when and where was the car built that you included in your post above. Just in case they are different at other plants or production periods?
« Reply #7 on: October 31, 2023, 10:49:19 AM »
Yeah...forgot to add that.
Marcus Anghel
« Reply #8 on: October 31, 2023, 12:15:51 PM »
Thanks added that to your post of the pictures  ;)
