Author Topic: 1966 289 smogpump belt  (Read 591 times)
Offline COBRAJET
« on: November 07, 2021, 11:11:40 PM »
I am having trouble finding the correct a/c smog pimp belt for a 1966 289 s/j built  ,the belt I found is way to short .Any help accepted
Re: 1966 289 smogpump belt
« Reply #1 on: November 08, 2021, 12:47:21 AM »
Ford Car Parts (aka MPC), 75 ed, section 86.1, says you need Ford Locator Code number JC-607 (service number C9PZ-8620-DE) a 1/2 inch wide, 60 7/8 "long" belt. Check your lower pulley diameter too. The outer sheath (of three) should be a smaller diameter than the two inner ones.
(The 1966 Ford Products Engine Equipment - - (AM0156 pg76) shows double inner belts, and the outer (A/C and smog) as C6ZE-8620-C, 1/2 X 60.00 inch, but that number does not appear in the MPC.)
Offline Deuce
« Reply #2 on: November 08, 2021, 12:51:43 PM »
Mannel's Ford Small Block V8 book (sections 6K20, 7K21) suggest that the 1966 and 1967 Mustang 289 with AC and T/E engine configurations were very similar.
I went through this belt-fitting exercise a while back for my 1967 coupe (signature car below).  A reproduction C7ZE-8620-C belt available from NPD and Marti Parts (Item number 8620-94) is the correct Smog + AC belt.  I believe C6ZE-8620-C would be the same part (?).  A Gates Green Stripe 9620 XL belt was on the car before, and would be interchangeable.  Both Gates and 8620-C belts measure 1/2" x approx. 60".
Deuce
Offline outlawincorporated
  • Kangaroo Herder
« Reply #3 on: November 08, 2021, 06:39:56 PM »
been down this track a few times with mixed results on the MARTI repo's so i went one step further and bought genuine examples only
the correct belt i have used several times on CONCOURS restored cars has been marked/embossed with C6ZE-8620-C2. i bought several NOS versions many years ago and only have 2 left now.
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
Offline Deuce
« Reply #4 on: November 08, 2021, 08:10:50 PM »
Excellent foresight, and a nice find!
Deuce
