Author Topic: TUNG-SOL marked 6012 headlight, application?  (Read 1874 times)
Online CharlesTurner
« on: November 02, 2021, 04:05:19 PM »
I have a 6012 headlight with the letters 'TUNG-SOL' along the bottom, not the typical t/s insignia.  It also has 'FoMoCo' oval etch in the center and 'Made for Ford' stamp on the back.
Any info appreciated.
Re: TUNG-SOL marked 6012 headlight, application?
« Reply #1 on: November 03, 2021, 12:20:48 AM »
Believe that 6012 with the Tung Sol spelled out was possibly for a 68 Mustang and other applications like an AMX and Javelin
Guess you didn't find a date stamp on the back side
Unfortunately the ones I have pictures have don't have a car's VIN to go with them
« Last Edit: November 03, 2021, 12:27:10 AM by J_Speegle »
« Reply #2 on: November 03, 2021, 12:37:18 AM »
I have had one of those before but do not know where it came from.
« Reply #3 on: November 03, 2021, 10:38:38 AM »
Didn't Marcus do a study on the date codes?
If not Marcus, someone did state that the date is part if that SAE number. If what I am suggesting has merit, wouldn't that be a 1961 date?
« Reply #4 on: November 03, 2021, 06:10:32 PM »
The decoding that way works for many taillight lens not sure if bulbs follows that.
Believe Marcus focused on 69-70 bulbs in his pdf don't recall if there was any dating info
Offline CT428CJ
« Reply #5 on: December 02, 2021, 10:28:22 PM »
Here are some pictures of one of the original Tung Sol headlamp bulbs from my April 24th 1968 Dearborn Mustang.
It's tough to get a good head on shot of the ink stamp but it's clear that the stamping is different than the one in the previously posted picture.
« Last Edit: January 26, 2022, 08:35:41 PM by CT428CJ »
« Reply #6 on: December 29, 2021, 10:38:46 AM »
ct429cj  that is correct 69 dearborn bulb for late april car but sometime shortly after april ford either ran out  or ( changed vendors) of the ts fomoco bulbs and no fomoco GE bulbs start showing up. I have been tring to document when exactly this change happened and 69 boss 429s are what i use to document this since most are low mile cars and the inner hi beam dont get used as much as outer low beam.
Offline Scott302
« Reply #7 on: December 29, 2021, 01:38:03 PM »
According to the Chrysler300club.com website tech section:  The "Tung Sol" spelled out at the bottom of the bulb started in 1961 and replaced the prior center located "TS" circle logo. It also states the "H61" indicates a 1961 date code.
Regards,
Scott
Scott Halseth
Ford Product Manager
National Parts Depot
MCA#01776
Offline DTruitt
« Reply #8 on: February 06, 2022, 07:49:24 PM »
It is my belief that Tung-Sol had at least two manufacturing plants making headlights, and this is one example of the differences in manufacturing at the time.  I think they made headlights in New Jersey and also a plant in Canada.
Danny
1968 Raven Black, S- Code, 4 spd., GT Fastback, San Jose, March 1968
1968 Candy Apple Red, J- Code, C-4, GT Convertable, San Jose, April 1968 (SOLD)
1968 Raven Black, R- Code, 4 spd., GT Coupe, Dearborn, April 1968
MCA Gold Card Judge
« Reply #9 on: February 07, 2022, 12:42:24 AM »
Regards,
Scott
That website info seems to contradict the TS marked bulbs that are commonly found on SJ and Dearborn cars from 1965 to at least the late 60's.
Offline hopey
« Reply #10 on: February 10, 2022, 11:46:33 AM »
Did this carry on into the ?70 production with the 7 inch  6012 sealed beams or was it a ?69 shortage only?
1970 BOSS 302
Built 11/15/69 Dearborn
« Reply #11 on: February 11, 2022, 11:04:40 AM »
I dont see fomoco marked headlights in 70 dearborn cars just TS on the bottom .
