Yes he does -- but only for 31 spline toploaders. Those are 2 1/2" OD. Mine is 2 3/8 OD.I mistook a C4 pic on the unrestored section as the extension housing for a toploader. Rookie error.My trans came with a 410059 National seal which has red paint around the outside. It also a metal shield on the inside where felt may have been between it and rubber seal. NPD says their 470059 is correct and the listing is for a 4 speed. It's red.I guess what I'm asking is the red band you will see when installed the correct assy line look?
