Author Topic: Under Dash Picture Dump - 68 SJ  (Read 540 times)
« on: October 17, 2021, 06:31:19 PM »
Had a request for under dash pictures in another thread and rather than bury them inside a different thread thought they should be posted separately so here you go.
You may recognize some of the pictures from other threads
UD-1 A couple shots of the bottom of the cowl surface just in case someone had had some repairs or panel replacement
UD-2
UD-3 A couple showing the opening for the gauge cluster showing how dash loom is held in place as well as other details in the area
UD-4
UD-5 General PS pad shots with everything else out of the way
UD-6 Also confirmation that the glove box was in place when the dash was painted. No primer or any paint where the hinge attached just like 67 San Jose. That is a solid line for  an aftermarket mechanical oil pressure gauge
UD-7 Drivers side/end of the under dash area. On this first example we see an aftermarket hood lock
UD-8 Wiper control
UD-9 Detail note - notice the safety read dyed retainer on the E brake cable wheel
UD-10 Under dash around the steering column picture on the DS of column. Notice that the  brake booster has been replaced by a blue aftermarket booster
UD-11 Shots of the area to the right, as you sit in the drivers seat,  of the steering column. AC car
UD-12
UD-13
UD-14 Non AC. Notice that its a shot from the other side of the area with the blue PB booster again.
UD-15 Center of the area under the dash without AC
UD-16 Picture from center of the dash facing DS with AC
UD-17 Air condition unit
Hope this helps others
« Last Edit: October 17, 2021, 10:41:01 PM by J_Speegle »
Re: Under Dash Picture Dump - 68 SJ
« Reply #1 on: October 17, 2021, 09:20:51 PM »
Great detail shots!
« Reply #2 on: October 18, 2021, 01:38:15 AM »
I am sure the collective "we" appreciate the effort .
