Author Topic: Fan shroud 1970 351C 4-spd  (Read 1607 times)
Offline hankmeister
« on: October 01, 2021, 01:21:19 PM »
The car is a 70 Sportsroof, 351C 4v, 4 speed, no air or ps.
So a few months I discovered the fan shroud on my Mustang was cracked/broken into 3 pieces. I got online to attempt to find a replacement. Found what I thought was correct from John's Mustang. Labeled for 302/351 with 24" wide radiator. Labeled as original tooling, part #D0ZZ-8146-A, from Daniel Carpenter Mustang. Unfortunately I was dumb enough to throw away the old shroud before attempting the new shroud. The radiator isn't a Ford original, but the size (24" wide) is spot on.
So I put on the new shroud, the fan hits at the bottom. Top & sides seem to be okay, but it hits the 6 o'clock (well, from about 5 to 7) position. I noticed the fan was aftermarket, so sourced what I believe to be the correct fan for a '70 - 5 blades, stamped D0ZE-B, I believe. Roughly the same diameter as the previous fan. Still hits at the bottom.
So - do I have the correct shroud?? Should I get a shorter spacer to pull the fan all the way out of the shroud, or a deeper spacer to try and get it right on the radiator? Which would be a pain to put on, I can imagine.... Frustrating, because before there was no problem at all.
Any advice/thoughts appreciated.
Hank
Hank
70 Fastback
351C / 4 bbl / 4 spd / front disc brakes
No a/c or p/s
Wimbledon Wht
Re: Fan shroud 1970 351C 4-spd
« Reply #1 on: October 01, 2021, 03:45:47 PM »
Since its not a factory radiator and if you have already adjusted the shroud downward as much as possible I would consider making the holes for attaching the clips and in turn the mounting bolts for the shroud longer - more of a slot for adjustment purposes. Guessing you only looking for an additional 1/8"-1/4" on both sides
Could do the same with the shroud though I can't see how your is formed and if there is any impediments to doing that in the shaping of it
Just a thought
Offline HDAshmore
« Reply #2 on: October 02, 2021, 01:09:38 PM »
This may be way off but is there any chance it's because of motor mounts?
« Reply #3 on: October 02, 2021, 04:34:45 PM »
Always a possibility
Offline hankmeister
« Reply #4 on: October 04, 2021, 03:47:29 AM »
I don't think so. The previous shroud and fan had zero problem. Everything fit perfectly. The motor mounts, afaik, are basically original dimensions, if not original mounts (truly don't know/remember). I've had the car so long (40 years now), and it's been so long since I did the fan shroud (if ever!), I don't know what I had. All I know is that the current setup doesn't work. I've contemplated just cutting out/trimming the bottom of the shroud, since I'm not entering the car in any shows.
all the best
Hank
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
« Reply #5 on: October 04, 2021, 07:00:15 PM »
I don't think so. The previous shroud and fan had zero problem. Everything fit perfectly. The motor mounts, afaik, are basically original dimensions, if not original mounts (truly don't know/remember)......
Of course we didn't know that and were only going through some of the possibilities of why things might not all be lining up
Offline hankmeister
« Reply #6 on: October 05, 2021, 02:36:49 PM »
No disrespect intended....wasn't sure how to accent my statement to have the word "think" sound like "maybe - but it was okay before...but who knows?" Something along those lines.
I value everybody's inputs and time to help me. Apologies if I came across wrong; the challenge of the written word!
Just a learning lesson not to throw away old stuff until the new stuff is on!  ;)
all the best
Hank
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
Offline hankmeister
« Reply #7 on: October 05, 2021, 02:56:28 PM »
Couple of pix
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
Offline cobrajet_carl
« Reply #8 on: October 11, 2021, 03:01:16 PM »
Well at the very least your fan isn't correct. D0ZE-B would not be correct for 1970. A 1970 351C with a 24" radiator would have a C8SE-B fan. 17 1/2" diameter, I think the one you have may be slightly larger. And make sure the pads on the lower radiator mounts aren't swollen or the wrong thickness. Attached is a pic of the fan from my March DB built M code 70 mach with 3.50 gears, which got it a 24" radiator.
« Last Edit: October 11, 2021, 04:28:10 PM by cobrajet_carl »
Carl
70 and 71 Dearborn mach Is
Offline hankmeister
« Reply #9 on: November 08, 2021, 05:26:43 PM »
Thanks Carl! I'll see what I can do to source one.  Hopefully that'll be the solution.
Hello Ebay.....
best
Hank
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
Offline BlackMcode1970mach1
« Reply #10 on: November 09, 2021, 08:58:03 PM »
This talk of fan shroud got me thinking   about the originallity of my car  . I looked at my fan and it reads cf DIDE  5600 BA .   SO this must be a 71 fan?  Its 17 inches in diameter.  I have a dearborn  car btw. non ac  car with a automatic . Knowing  what  was done to my car it dont surprise me on things lol..   It came from alabama  not sure how it got to wisconsin  . Mark
« Reply #11 on: November 11, 2021, 04:31:35 PM »
Yep 71 or even later. Date code would help determine if your inclined to check
Offline hkopp
« Reply #12 on: November 22, 2021, 01:57:33 AM »
If you can get him down on the shipping...here's one.
https://www.ebay.com/itm/1969-MUSTANG-BOSS-302-COUGAR-ELIMINATOR-FAN-BLADE-ORIGINAL-H69-DATE-CODE-LOOK-/184877504925?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0
There are a few others...
Hello Ebay.....
best
Hank
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1965 Mustang 347, 5 spd, 1st car!
1967 Camaro SS350 all #'s
1967 S code
1969 Mach 1 428SCJ-R #'s
1969 Mach 1 428CJ-Q Auto
1969 Mustang Grande, 650hp, 2nd car!
1970 Mustang
1970 Mach 1 351C
1975 Ford F250, 44s, 21" lift, 3rd car!
2002 Avalanche
2011 Vette
Offline hankmeister
« Reply #13 on: December 02, 2021, 06:54:09 PM »
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
