Author Topic: Front spring markings  (Read 2373 times)
Offline dbm350
« on: February 24, 2011, 12:05:39 AM »
   Am I correct that the front spring marking for a mid April San Jose K code fastback  would be one red stripe?   Thanks, Doug
Re: Front spring markings
« Reply #1 on: February 24, 2011, 12:15:52 AM »
Year?
Offline dbm350
« Reply #2 on: February 24, 2011, 12:21:50 AM »
     Sorry ,  1966
« Reply #3 on: February 24, 2011, 01:47:59 AM »
Found mine to sort of a brick red but I've seen a few (just before yours in sequential numbers) that were a solid fire engine red. Of course you could have had the over or under stripe but if yours are missing just the one stripe would be my suggestion  ;)
Offline dbm350
« Reply #4 on: February 24, 2011, 02:33:03 PM »
   Thank you Jeff.
Offline SanJose64
« Reply #5 on: February 25, 2011, 01:18:58 PM »
jeff could you tell me what the markings is on the front and back springs are? 19641/2 prairebronze#89 trim code. thanks sanjose64.
« Reply #6 on: February 25, 2011, 09:29:09 PM »
Would need to know
- What body style
- What engine
- What transmission
- Projected build date
- AC or non AC
- PS or non PS
- Engineering numbers from the rear springs would really help narrow down the possibilites
Offline SanJose64
« Reply #7 on: March 04, 2011, 05:23:38 PM »
Hi jeff 19641\2 conv,289,auio,july,13,no, ac, ps,jeff could you please tell me where the number is on the springs .front and back.thanks sanjose64
« Reply #8 on: March 04, 2011, 08:54:06 PM »
There are no part numbers on the front springs so not sure of how that would help and the only Ford books I have show the replacement numbers - not certain they are the original numbers.  Same goes for the rears - I can find out what Ford used to replace the originals - not what was on your particular car originally - the reason I'm always asking what the engineering numbers are on a set of springs when someone asks about the paint marks on them.  ;)
Was there the thought of using the Master Parts Catalog to figure out the paint marks originally on th esprings? If so - don't do it   :o
