Author Topic: Inner fender punch  (Read 3721 times)
Re: Inner fender punch
« Reply #15 on: September 06, 2021, 01:30:33 PM »
The hand nibbler requires a 3/8" diameter hole be drilled to start with. From there it's maybe 15 bites per nutplate square hole in an inner fender apron.
« Reply #16 on: September 06, 2021, 01:38:28 PM »
Several more hand versions on eBay too. Here's an example exactly like mine:
https://www.ebay.com/itm/224588139216?hash=item344a7f0ad0:g:3xUAAOSwDGFhKUXw
« Reply #17 on: September 06, 2021, 01:51:49 PM »
If carefully used, it will work fine. Drill out the center of the rectangle you need, and "trim" the rest - again, carefully.
« Reply #18 on: September 06, 2021, 03:42:20 PM »
OK, drill 4 holes with the correct corner radius, jig saw inboard of final fit and use a small belt sander or file to smooth things out between the holes.
These mini sanders are very useful.
