Author Topic: Rear Backing Plate Details  (Read 1351 times)
« on: September 03, 2021, 05:06:01 PM »
Had a question related to a specific hardware details which made me think that I should post that picture and start a thread with other details related to the subject in the title. Some of these details relate to many years but will start here.
There were two suppliers of brake supplies to Sterling that made up the rear end assemblies that would, once completed, to the car assembly plants. The subassemblies provided by the suppliers came preassembled and basically were just attached to the ends of the rearend housing when the rest of the items to added. Subassemblies included backing plate, brake shoes, wheel cylinder and all the hardware to hold them in place.
The two suppliers were Kelsey Hayes and Bendix
Backing plates were painted with a heavy coat of semi-gloss black - typically glossier than the housing likely due to how they were painted and that they were painted by the supplier. Each supplier marked their backing plates differently. You will find company names and in one case FoMoCo in an oval.
Casting details for the wheel cylinders were different and so was the hardware. Below are a couple of 69 examples showing the bolt heads from Kelsey Hayes examples
There were date codes (ink stamped) applied to both suppliers subassembles for identification and tracking purposes.
In the brake show adjustment hole a rubber plug was suppose to be installed after the shoes were adjusted. The visible flat face of the plug would have had either a series of very fine diagonal lines that formed a cross hatch pattern slightly raised from the surface if supplied by Kelsey Hayes or a series, 8A-2092, if supplied by Bendix
Offline Aussiemach
  • Silver Level Subscriber
Re: Rear Backing Plate Details
« Reply #1 on: January 17, 2022, 12:44:21 AM »
1969 rear brake wheel cylinder mounting bolts,
In the photo:Left - Kelsey Hayes, Right - Bendix
Kelsey Hayes was on LH side of the rear axle and Bendix on the right.
Kelsey Hayes backing plate
Bendix backing plate
« Last Edit: January 17, 2022, 01:02:15 AM by Aussiemach »
1969 Mach 1 351w FMX Built in San Jose, February 26 1969
Offline Aussiemach
« Reply #2 on: January 17, 2022, 01:05:32 AM »
Would finish would the rear brake wheel cylinder mounting bolts be ?
Offline Aussiemach
« Reply #3 on: September 03, 2022, 08:24:52 AM »
I?m assuming phosphate & oil finish on the bolts ?
« Reply #4 on: September 03, 2022, 08:48:11 AM »
correct.
« Reply #5 on: September 03, 2022, 05:55:00 PM »
correct.
Before you jump to conclusions, Ford service documents call out either clear zinc or cadmium plating (-S7/8). AMK (Max had access to Ford documentation to reproduce hardware) calls out clear zinc (-S8) and phosphate (-S2) for several of the bolts.
Your choice.
Offline Aussiemach
« Reply #6 on: September 03, 2022, 11:04:07 PM »
Thank you
