Author Topic: 68 390 GT Heat riser & S tube pictures  (Read 792 times)
Offline duffman
« on: September 03, 2021, 12:04:44 PM »
Would appreciate photographs of the correct riser and S tube.  I have seen two variations, one with the cutout on the bottom of the riser, on West Coast Cougars,
and cars with no cutout.
Are both correct?   Could I use the latter without the cutout?
Please PM me if you have a correct one lying around...
Thanks.
« Last Edit: September 03, 2021, 01:20:33 PM by duffman »
Born on 12/14/17 San Jose 68 S Code convertible 4speed, deluxe interior & seatbelts, 8 track in console, 3:25 Conv rear, GT package, PS, PDB,PT, Convenience Panel, Visibility, Reflective & Blackout packages
Re: 68 390 GT Heat riser & S tube pictures
« Reply #1 on: September 03, 2021, 05:20:06 PM »
The 68 is a one year only style heat shield. Believe you will find its a two piece unit like the example shown below that was identified by the owner when posted
Often see them for sale with only the outer section as these are not easy to install or remove with the engine in the car
Think the S tube is shaped like the 428CJ though the screw hole may be located differently. Sorry don't have pictures of specific details on that subject handy
Offline duffman
« Reply #2 on: September 05, 2021, 05:41:45 PM »
Jeff,
Many many thanks.  Your expertise, depth and ability to assist is greatly appreciated! Once again, the hunt is afoot.
Offline CT428CJ
« Reply #3 on: September 06, 2021, 09:36:18 AM »
1968 390 GT S tube at top and later 428 CJ S tube at bottom.
« Reply #4 on: September 06, 2021, 05:22:21 PM »
Thanks for posting - forgot about the trimming of the top/wider neck joining seams
Offline duffman
« Reply #5 on: September 07, 2021, 07:59:22 PM »
Thanks,    I saw Semo makes a repop of the tube for a 428.  Could I use it by trimming  the top and  cutting the flanges back?
« Reply #6 on: September 08, 2021, 04:40:24 PM »
IF your very careful I'm pretty sure it would work. Your going to need a picture of how the uncrimped edges at the top look before you start
Offline duffman
« Reply #7 on: September 24, 2021, 06:16:24 PM »
Semo does make a 390 S tube, FYI
