Here you go - hope it helps
Vacuum routing "T" at firewall
Passenger side of engine compartment
Battery check decal (purple arrow) You'll likely get a decal for the voltage regulator and coil though both were originally ink stamped NOT decals (yellow arrows)
Drivers side engine compartment
Air cleaner decal (yellow arrow), Air filter service decal make sure your reproduction has the filter ID number in the lower left corner (light green arrow), timing decal - found in one of two slightly different locations - see below also (red arrow), service spec decal notice orientation (dark green arrow)
Air filter service decal make sure your reproduction has the filter ID number in the lower left corner (light green arrow), timing decal - found in one of two slightly different locations - see above also (red arrow), engine ID decal (purple arrow)
