Author Topic: 70 door panel markings  (Read 1715 times)
« on: August 25, 2021, 09:18:46 PM »
I saw a similar thread for 65 and 67, so figured we might keep the odd pattern going...  Correction, this is from a 1970 Mach 1.
« Last Edit: August 26, 2021, 06:55:20 PM by 67gta289 »
Offline JohnB
  • 0F03R120303
Re: 69 door panel markings
« Reply #1 on: August 26, 2021, 05:48:38 PM »
Quality controll November 6, 1969! Must be for a 1970 or??
Re: 70 door panel markings
« Reply #2 on: August 26, 2021, 06:54:48 PM »
Any info on the car that it came from?  I'm betting its a San Jose built car.
This is from the 1970 Mach 1 door I picked up at the junkyard.  The car is long gone - there are seven 69 Mach 1's but no 70's left.
Same door as the cladding shown in this link: https://www.concoursmustang.com/forum/index.php?topic=25284.0
I included here a few date stamps from the inner door structure.  I've got nothing else to offer other than by default I assume that any Mustang here in Michigan was assembled in Dearborn, and want to see evidence to prove otherwise.  Looks like you have just that - thanks.
« Reply #3 on: August 26, 2021, 06:55:40 PM »
Jeff - can you move this to the 1970 area?
« Reply #4 on: August 27, 2021, 06:08:00 PM »
For you? Yes :)
Separated my 69 post for a new thread over in the 69 section
Offline cobrajet_carl
« Reply #5 on: August 27, 2021, 08:54:39 PM »
Guess I'm missing something but what evidence indicates the build plant?
Carl
70 and 71 Dearborn mach Is
« Reply #6 on: August 28, 2021, 04:59:55 PM »
We split the topic from the 69 stuff so we're now missing some findings and have not gotten additional 70 examples. The thought is, like many parts, multiple suppliers were used by Ford and usually one supplier supplied Dearborn and and NJ while another San Jose. Shocks being one of those examples. This does not mean that in some situations a produced typically produced and supplied to one plant could not be redirected (one shipment for example) to a second plant if the usual supplier could not provide the part at that time
In the 69 thread I showed the inspection mark of two different suppliers confirming the multiple suppliers that year. Just going through the steps to see if we can determine, by inspector, patterns of writing on the inside surface and even handwriting we can determine where the car was built that the door panels came off of.
69 Thread - https://www.concoursmustang.com/forum/index.php?topic=25310.0
« Last Edit: August 28, 2021, 05:13:26 PM by J_Speegle »
« Reply #7 on: August 28, 2021, 05:21:43 PM »
Couple of pictures I could in my collection
70 Dearborn deluxe panel - 0F1102xx
70 San Jose deluxe panel - 0R1328xx Red and black numbers
70 San Jose standard door panel - 0R1577xx. Guess at this point we can't assume that the supplier for the Deluxe panels was the same as the standard
Offline boss167961
« Reply #8 on: August 30, 2021, 06:20:56 AM »
Images from my deluxe interior June 24 70 Boss 302
Martin
