Author Topic: June 27th 1969 Boss 302 Steering Gearbox Color  (Read 4343 times)
Offline Gcodecowboy
« on: August 21, 2021, 11:43:52 AM »
I have a June 27th 1969 Boss 302. It has a steering gearbox with a serial # SMB K 9F20B. What color should it be? If it should be a gunmetal bluish color, does anyone have a picture of how dark the cast surface should be?
Thank you,
Mike
06/27/1969 Boss 302
Re: June 27th 1969 Boss 302 Steering Gearbox Color
« Reply #1 on: August 21, 2021, 12:34:33 PM »
Thank you,
Mike
The body should have the look of fresh cast bare cast iron which is darker then bead blasted. The other parts are machine steel and will contrast with the body. If you read the assemblyline manual there are instructions to paint with a brush what you can see from above. That is referring to the top of the box so that a Ford buyer will not potentially see flash rust on the top of the box when looking down in that area. Typically a 2 inch brush and  semi gloss black paint done sloppy and not totally covering the top showing brush marks over the top edge sides based on examples is used to replicate the look. Although the manuals included specific instructions not all were done that way.
« Reply #2 on: August 21, 2021, 05:35:33 PM »
Here is a picture of a new steering box showing the main body cast color and the machined surfaces
Offline Gcodecowboy
« Reply #3 on: August 21, 2021, 07:54:52 PM »
Thank you Bob
06/27/1969 Boss 302
Offline Gcodecowboy
« Reply #4 on: August 21, 2021, 07:55:20 PM »
Thank you Jeff
06/27/1969 Boss 302
