Author Topic: 68 S Scode Power Steering Belt Alignment  (Read 2403 times)
Offline duffman
« on: August 20, 2021, 09:54:39 AM »
I just purchased the correct pulleys & belts from Bill @ Mansfield Restoration.  Great guy and very knowledgeable.
The PS belt is not in alignment with the crank pulley.   As it seems that a lot on this car was swapped or replaced, I
can only assume its the wrong PS bracket or spacer.
Any guidance would be appreciated.   So close.....
Born on 12/14/17 San Jose 68 S Code convertible 4speed, deluxe interior & seatbelts, 8 track in console, 3:25 Conv rear, GT package, PS, PDB,PT, Convenience Panel, Visibility, Reflective & Blackout packages
Offline duffman
Re: 68 S Scode Power Steering Belt Alignment
« Reply #1 on: August 20, 2021, 10:16:31 AM »
I think the bolt and spacer may be the culprit, no?
Offline Coralsnake
« Reply #2 on: August 20, 2021, 11:37:36 AM »
The spacer is not correct so it might be a good place to start. The ps bracket should have a long stud with a nut (not a bolt) otherwise brackets look correct
« Last Edit: August 20, 2021, 11:52:41 AM by Coralsnake »
Offline Coralsnake
« Reply #3 on: August 20, 2021, 11:38:33 AM »
And you might want to check your ps pulley for correct application
Maybe post your pulley info here so we can make sure you have the correct pieces?
I think these are correct
Pulley             Pulley ID Number
Crankshaft      C8AE -6312-D
Water Pump      C8OE-8509-A ( no stamping visible )
Alternator   Steel      Dual style
Power Steering      6AA
« Last Edit: August 20, 2021, 11:51:31 AM by Coralsnake »
« Reply #4 on: August 20, 2021, 02:18:00 PM »
Looks like the incorrect PS pump pulley if the car has no A/C. If it?s a no A/C car the pump pulley only connects with the most forward sheave on the crank pulley.
« Reply #5 on: August 20, 2021, 03:10:07 PM »
+1 . The picture shows a AC power steering pulley on a non AC car. The correct non AC pulley will have a offset towards the front of the car.
Offline duffman
« Reply #6 on: August 20, 2021, 05:30:41 PM »
Its a non AC car, so wrong pulley and bolt/spacer...
Wonderful.
« Reply #7 on: August 20, 2021, 06:01:16 PM »
Wonderful.
I have a hard time viewing the annoying oversize pictures but it looks like the PS aluminum bracket is fine . Yes the small diameter spacer is wrong. You are missing the larger diameter .50 inch thick, steel spacer needed on a non AC car.  https://www.npdlink.com/product/spacer-power-steering-pump-mounting/148922   The AC compressor bracket takes the place of the spacer on a AC car. A bolt is not used to hold the bracket and spacer to the head . Instead a long stud is used with a locking nut to hold in place. The same stud and nut are used regardless of if AC or not.
« Last Edit: August 20, 2021, 06:06:58 PM by Bob Gaines »
« Reply #8 on: August 20, 2021, 07:31:46 PM »
Since you need all the mounting hardware and not just the spacer I would just get the F-1154 kit from AMK:
https://www.amkproducts.com/i-kits/ford/?year_=1968&model=Mustang&category=Steering%2FSuspension
Dead Nuts On carries the correct pulley reproduction if you can't find an original.
« Last Edit: August 21, 2021, 10:46:09 AM by RoyceP »
Offline duffman
« Reply #9 on: August 21, 2021, 09:26:40 AM »
Bob,
Photos are uploaded from phone.  Site doesnt give you an option t resize.  Moving forward I will adjust.
1 step closer to getting it done right.
