Author Topic: '68 NJ brake booster hose clamps  (Read 4511 times)
« on: August 19, 2021, 08:13:34 PM »
For a late April '68 NJ car w/302, what is the typical clamp configuration for the power booster vacuum hose?  I have a crimp clamp at the booster check valve and a spring clamp with squared ends on the intake side.
Re: '68 NJ brake booster hose clamps
« Reply #1 on: August 19, 2021, 10:39:17 PM »
I would use the typical crimp clamp in your case.
« Reply #2 on: August 19, 2021, 10:52:24 PM »
Guess I should have noted it is a '68 GT350 4sp with aluminum intake... if that makes any difference.
« Reply #3 on: August 21, 2021, 05:46:49 PM »
Went though my pictures and allot of examples had been played with.
One I found that might be as it was originally is shown below
« Reply #4 on: August 21, 2021, 06:28:43 PM »
Thanks Jeff, that's what I have on the car currently... and a crimp clamp over by the booster check valve.
« Reply #5 on: August 21, 2021, 06:30:55 PM »
Yes it might be original but from what time period ? There was no doubt a change over time in 68 from one style to the other.
« Reply #6 on: August 22, 2021, 04:56:52 PM »
The example is from 8T03J1942xx. Pretty close to the car the information was requested for.
« Reply #7 on: August 23, 2021, 01:28:41 AM »
Jeff... in your pic, it is showing tall carb nuts.  I know on earlier Shelby's they could be taller than regular Mustangs, but is that something that continued on?  I guess I just assumed '68 would use the same mounting nuts as a Mustang?
Offline TLea
« Reply #8 on: September 02, 2021, 12:59:54 PM »
Regarding the booster clamps it would be a spring clamp on manifold side and keystone clamp on booster side unless cast iron manifold car that never went back for recall. That would have 2 keystone clamps
