I am looking for a reference photo that shows the 5 brake hoses in the photo installed. I could not make it out in the assembly manual
I think you have a typo because the picture shows powersteering hoses.
Might help.. I?m not quite finished but it should help..
I find that if you get the pressure line on first, then the return line running over the top, they sit a lot nicer..
Blue Dot hoses on a '68 428CJ that I am restoring.
Great thanks Royce. What type of hose clamp is that. My car was missing the clamp. I may have a few more questions if that is alright
A screw clamp was used in 68 for the power control valve. #16 marked Suretite.
This is meant to be helpful but FYI since you are going to the trouble of trying for a historical look using OEM looking PS hoses, assemblyline finish's etc. I thought you should be aware that the tie rod adjusting sleeves are obvious replacements given the distinct non assemblyline contour down their length.
