Author Topic: 1968 GT 390 San Jose Brake Hoses  (Read 1985 times)
Offline bullitt68
« on: August 19, 2021, 04:10:23 AM »
I am looking for a reference photo that shows the 5 power steering hoses in the photo installed. I could not make it out in the assembly manual
« Last Edit: August 19, 2021, 04:38:48 AM by bullitt68 »
Mike
Re: 1968 GT 390 San Jose Brake Hoses
« Reply #1 on: August 19, 2021, 04:21:40 AM »
I am looking for a reference photo that shows the 5 brake hoses in the photo installed. I could not make it out in the assembly manual
I think you have a typo because the picture shows powersteering hoses.
Offline bullitt68
« Reply #2 on: August 19, 2021, 04:38:30 AM »
Doh! Yes, you're right. I meant power steering hoses
Mike
Offline 67GT500
« Reply #3 on: September 10, 2021, 08:49:52 PM »
Might help.. I?m not quite finished but it should help..
« Reply #4 on: September 10, 2021, 09:57:14 PM »
Blue Dot hoses on a '68 428CJ that I am restoring.
Offline 67GT500
« Reply #5 on: September 10, 2021, 11:21:40 PM »
I find that if you get the pressure line on first, then the return line running over the top, they sit a lot nicer..
Offline bullitt68
« Reply #6 on: September 10, 2021, 11:32:54 PM »
That is perfect thanks. Great work. I may need to ask a few more questions if you don't mind
Mike
Offline bullitt68
« Reply #7 on: September 10, 2021, 11:34:02 PM »
That's great thanks. Are those blue dot hoses
Mike
Offline bullitt68
« Reply #8 on: September 10, 2021, 11:35:31 PM »
Great thanks Royce. What type of hose clamp is that. My car was missing the clamp. I may have a few more questions if that is alright
Mike
Offline 67GT500
« Reply #9 on: September 10, 2021, 11:39:42 PM »
Yes,Blue Dots..
« Reply #10 on: September 11, 2021, 12:23:00 AM »
It?s the original one. I think you can get one from DNO.
« Reply #11 on: September 11, 2021, 01:03:27 AM »
This is meant to be helpful but FYI since you are going to the trouble of trying for a historical look using OEM looking PS hoses, assemblyline finish's etc. I thought you should be aware that the tie rod adjusting sleeves are obvious replacements given the distinct non assemblyline contour down their length.
« Reply #12 on: September 11, 2021, 01:09:00 AM »
A screw clamp was used in 68 for the power control valve. #16 marked  Suretite.
Offline bullitt68
« Reply #13 on: September 11, 2021, 01:15:57 AM »
Great thanks Bob appreciate it
Mike
Offline 67GT500
« Reply #14 on: September 11, 2021, 06:50:32 PM »
Thanks Bob, I was wondering that as I was cleaning them up.. I have some correct ones that I will use..
