Author Topic: oil dip stick tube c6az-6754-a  (Read 2568 times)
« on: August 05, 2021, 04:52:45 PM »
Bummer - my 67 289 dip stick tube busted.  Looks to be part number c6az-6754-a.  I can hit up the junkyard, should have 20-30 to pick from, and will probably give that a solid attempt.  However, if all else fails how good are the repros?
Re: oil dip stick tube c6az-6754-a
« Reply #1 on: August 05, 2021, 05:06:02 PM »
Good . Have fun getting the tube out undamaged. Typically tedious and can be hard to do. Best of luck.
« Reply #2 on: August 05, 2021, 07:25:32 PM »
Understood.  Since I see people looking for timing chain covers, maybe I'll go all the way and grab those, then I can get the tube out in a shop environment.
« Reply #3 on: August 05, 2021, 07:46:59 PM »
Easy to pull with the oil pan off.
Insert a 5/16" bolt inside the tube (inside the oil pan) and tap it out.
« Reply #4 on: August 05, 2021, 09:16:27 PM »
yes but not so when the engine is in the car...in a junkyard...with oil pan on the ground...
« Reply #5 on: August 05, 2021, 09:22:33 PM »
A for sale timing cover WITHOUT a dipstick is nothing out of the ordinary so selling the cover should not be a issue.
« Reply #6 on: August 05, 2021, 09:25:28 PM »
Thanks Bob
« Reply #7 on: August 06, 2021, 10:47:11 PM »
Sawzall!
« Reply #8 on: August 07, 2021, 07:14:01 AM »
No kidding.  I often go through 3 or 4 batteries on each trip!
« Reply #9 on: September 05, 2021, 04:28:45 PM »
FYI the Scott Drake repro had an O.D. of 0.380 whereas the original is 0.375.  Ridiculous.
« Reply #10 on: September 05, 2021, 05:16:34 PM »
Paint it with shrink paint -  ;D
« Reply #11 on: September 05, 2021, 10:37:49 PM »
Doesn't that paint come in a shrink tube?
