Author Topic: Jack 69 Mustang late production  (Read 642 times)
Offline vorrath
« on: July 28, 2021, 03:02:00 PM »
Looking for original jack for 69 Mustang  and handle
Offline rustbucket
Re: Jack 69 Mustang late production
« Reply #1 on: July 29, 2021, 04:43:19 PM »
Ive got a milk crate full of original mustang jacks and handles , but not sure which is correct for 69
would that be the flip top design ?
« Reply #2 on: July 29, 2021, 05:07:15 PM »
there is an excellent article on jack i.d.in the library section here.
« Reply #3 on: July 29, 2021, 05:14:00 PM »
The Jake ID guide in the library section is a very good starting place. The 67-70 jacks look about the same .With that said when you get down to it there were different jack mfg. designs that different plants typically used. Where the car was built is important if you are concerned about the one that would be most assemblyline correct for your car. Hopeful potential sellers will know the difference given where the car was built.
Offline vorrath
« Reply #4 on: September 23, 2021, 02:50:15 PM »
Yes flip top
« Reply #5 on: September 23, 2021, 07:27:01 PM »
Yes flip top
You didn't elaborate on which plant your car needing a jack was built at. That info will help get you the most accurate assemblyline type but if that does not matter then you have a much larger pool of candidates (all 67-70 varieties) . If it does matter then the information is important to get the most accurate one.
