Author Topic: 65 Assmebly Line V8 Oil Filters  (Read 23817 times)
Offline Twilight65
  • Gold Level Subscriber
« on: February 20, 2011, 11:29:09 AM »
Well it's finally started to warm up around here and I wanted to try out my oil filter stamp that I had made. Turned out pretty decent. I know the stamp is upside down and on the wrong type filter. But now all I"ll have to do is get the correct oil filter, paint and stamp.  Moving my car one more step towards that assembly line look.
Dave
Offline Skyway65
Re: 65 Oil Filter Stamp
« Reply #1 on: February 20, 2011, 02:00:50 PM »
Looks great :)
Couple of questions:  What kind of paint/ink did you use? And, what technique did you use to apply the ink to get to so even?  I've been experimenting with my coil stamp and I can't get it to look right.
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline Twilight65
« Reply #2 on: February 20, 2011, 02:17:58 PM »
Hey Gary, I tried the first time with spraying yellow spray paint on paper and stamping into it which I've done in the past with a lot of success.  This time with it being so large I just held the stamp and sprayed the yellow paint onto the stamp, just two or three quick shots,  then rolled it around the oil filter.  Believe it or not that was just my second try.
Dave
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #3 on: February 20, 2011, 02:35:08 PM »
Cool!   Good Job.   Did all the plants use filters with this marking in 65 and 66?
66 Metuch Conv
Nightmist, Std Blu Int
Offline Skyway65
« Reply #4 on: February 20, 2011, 02:41:26 PM »
Dave-  Thanks for that,: I'll have another go at the coil!  Gary
Gary Schweitzer
MCA #00181
Traverse City, MI
« Reply #5 on: February 20, 2011, 02:43:24 PM »
for coils that i do i purchased a silver ink pad. it goes on good.
Offline $64stang
« Reply #6 on: February 20, 2011, 03:19:13 PM »
I saw a diamond shaped  stamp, on the top of a filter like the one you are making too.
Offline Skyway65
« Reply #7 on: February 20, 2011, 03:45:55 PM »
I tried 4 different kinds of stamp pads.  They don't dry! 3 weeks later the ink wipes right off!
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline Brant
« Reply #8 on: February 20, 2011, 04:05:01 PM »
Dave
Great job stamping that, Dave.  That really looks good.
« Reply #9 on: February 20, 2011, 04:19:06 PM »
Looks good - keep it up
Offline bryancobb
  • 2009 Ridn' Around
« Reply #10 on: February 20, 2011, 04:39:41 PM »
OneShot Lettering Enamel is what you should use if you want it to last!!!!!!   It has lead in it.
66 Metuch Conv
Offline C5ZZKGT
« Reply #11 on: February 27, 2011, 06:47:23 AM »
Dave
Looks GREAT!! I remember seeing an ultra high dollar original assembly line filter a couple of years ago and I thought the stamp was the same direction as yours......what kind/type of paint did you use? I've also had a stamp made and have tried acrylic hobby paint and kind of rolled the stamp onto the filter......haven't perfected it yet though.
Offline Twilight65
« Reply #12 on: February 27, 2011, 09:55:16 AM »
I've always just used spray paint on all the stampings I've done. Ive tried pads but not with the same success. Normally I would spray the paint onto a paper plate and stamp back and forth on a dry paper plate until I felt the paint on the stamp was right an then stamp the part.  Because of the size of this stamp  I wasn't getting the paint on the center of the stamp. After doing that with the first try on this filter and rolling it around the filter it looked bad. So I cleaned up the stamp and tried just spraying the pint directly onto the stamp with about 3 quick shots of the spray can. Then I rolled it around. I couldn't believe how well it turned out. I painted the correct oil filter today with the double crimp on the top. I will let it dry a couple of days before stamping. (just in case I have to clean and restamp more than once)Hope I get the same result.
Dave
Offline Texas Swede
« Reply #13 on: February 27, 2011, 11:26:32 AM »
Dave,
Would it be possible to get your stamp manufacturer to do some extras which you could sell. I'll be interested, for sure.
Texas Swede
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #14 on: February 27, 2011, 11:31:40 AM »
This is the photo that was on ebay. Dave it however looks really nice!
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
