Author Topic: Distributor Cap Hold Down Clamp Rivet  (Read 5793 times)
Offline 196667Bob
Re: Distributor Cap Hold Down Clamp Rivet
« Reply #15 on: August 02, 2021, 08:57:32 PM »
Scott : Thanks for the clarifications.
Just seems to me that, based on what I have seen over the years, the "greenish tint" should apply to a lot more than just 1965-66 years.
Bob
MCA 04909
« Reply #16 on: August 02, 2021, 11:46:42 PM »
Bob
+1 It should because it does.
Offline 196667Bob
« Reply #17 on: August 03, 2021, 12:16:27 AM »
Then shouldn't the MCA Judging Rules be revised to reflect that for all years, not just 1965-66 Shelbys ?
Bob
MCA 04909
« Reply #18 on: August 03, 2021, 01:25:46 AM »
Bob
This was addressed about 10 or so years back when I was NHJ.  We took all the sheets and made them consistent across the board, mostly in section wording and points allocated, even up into 4th generation.  Since I stepped down, there has been some 'creep' in the rules as they have been revised many times since then and sometimes the changes aren't propagated to all years.  It's hard to reel it back in, but I think Scott is on the right track in collaborating with the Shelby ANHJ.  Basically, it comes down to someone taking the time to look at the bigger picture and ensure consistency.
Offline 196667Bob
« Reply #19 on: August 03, 2021, 01:48:33 AM »
Charles : Thanks for your input. I believe you are correct ; it's taking the time to be consistent.
Bob
MCA 04909
Offline Scott302
« Reply #20 on: August 03, 2021, 03:10:50 PM »
Unfortunately the consistency across all classes went out the window when the 65-66 guys completely re-wrote the body fit and finish section some years ago.  No one else wanted to go to the line by line setup that was done for 65-66.  There is resistance to changing any rules in certain classes regardless of the new knowledge gained.
Now back to the pin finish debate... had the boss dig into the collection of low mileage original cars and here is what he found:
1st image 65 Galaxie 14 miles.  Described as "slightly goldish but could be patina"
2nd image 65 Mustang 6 cyl 1800 miles.  "This is the shot that almost caused me to think that the rivet was the same finish as the clamp itself."
3rd image 69 Mark III, 3500 miles
4th image 70 Mach 1 5200 miles. "Looks silver to me.  Perkins had the motor out to detail, but I doubt he touched the hold down clamp pins."
5th image 70 F100 44 miles.  "It has a 'hint' of goldish tone to it.  But just barely a hint."
« Last Edit: August 03, 2021, 06:42:41 PM by Scott302 »
Scott Halseth
Ford Product Manager
National Parts Depot
MCA#01776
« Reply #21 on: August 03, 2021, 05:09:57 PM »
'Unfortunately the consistency across all classes went out the window when the 65-66 guys completely re-wrote the body fit and finish section some years ago.  No one else wanted to go to the line by line setup that was done for 65-66.'
i was against this from the start. too cumbersome/time consuming. we were doing fine before that in that area. obviously i was outvoted.
Offline rockhouse66
« Reply #22 on: August 03, 2021, 06:48:34 PM »
Scott
As I said at the beginning, I haven't seen a trace of color on the many original distributors that I have worked on or disassembled (all FE distributors, BTW).  You would think that the portion of the pin under the pivots would retain some original finish (if there were some).
'66 GT FB
« Reply #23 on: August 03, 2021, 07:17:19 PM »
a couple questions no one has asked yet.....were all distributors made at the same place??
any variance in colors between big block & smallblock?
Offline 196667Bob
« Reply #24 on: August 03, 2021, 08:01:15 PM »
Scott : Thanks for the further explanations and pictures. Based on the pictures, it appears that the majority of the rivets were just plain dull silver. That would explain why the many I have seen that I thought the green tint had just "gone away" with time, appears just dull silver, because they were.
Of course that some supplier's finish could have had a green tint to it, but wouldn't explain why all 1965-66 Shelby's have to have a "greenish tint".
Thanks again,
Bob
MCA 04909
Offline Scott302
« Reply #25 on: August 04, 2021, 05:19:09 PM »
Scott
That's kinda what the field trip into the car collection was about.  I didn't originally tell Rick what color I was looking for, only trying to see if there was a finish on the rivets.  Rick checked again and he can find no trace of green on any car/truck and the only color is as he noted in the first run through.  I'm not seeing any way to substantiate a "must be green" rule.
The distributors would have been assembled at one of the Ford component parts plants or an Autolite plant.  Made some calls and no one at Ford, so far, has any clue.  Submitted the question to the Benson library and I am awaiting a response.
Regards,
Scott
Scott Halseth
MCA#01776
Offline Scott302
« Reply #26 on: August 10, 2021, 05:30:40 PM »
So my Ford engineer friend came through for me.  He located the blueprint for the B-12145 rivet.  According to my friend the blueprint shows 2 materials; SAE CA260 brass and SAE 1010 steel.  The coating is listed as zinc plate ESF-M1P4-A.
Regards,
Scott
Scott Halseth
MCA#01776
« Reply #27 on: August 10, 2021, 07:12:11 PM »
Regards,
Scott
I for one have not seen any in brass before. The obvious question is can you find a further description of what ESF-M1P4-A looks like . It didn't show up in the search's that I tried.
« Reply #28 on: August 10, 2021, 08:40:45 PM »
Not the look, just a pic from a stds doc:
« Reply #29 on: August 10, 2021, 10:43:57 PM »
Finally got out to the small stack of original distributors as promised
The picture on the left best represents what I found on a couple of dozen units built in 68-69 and given to a high school for their usage so these have been stored well. In the upper right some have the plating/coating changing (were not like this ten years ago) and are turning a chalky yellow. Don't know why
Original coating is very thin and the goldish with a slight tint of green as I've seen on others. Believe describing them as "green" by itself would be historically incorrect just as it would be to describe, by itself, carburetors, ported vacuum switches, some emission parts and tubing
End of the clip and how they were finished off is just an addition detail I thought I would include
« Last Edit: August 10, 2021, 10:47:07 PM by J_Speegle »
