Author Topic: Interesting Inspector Paint OK Stamping  (Read 1533 times)
Offline K-HESS
« on: July 22, 2021, 07:40:25 PM »
Found this inspector stamping on a 1969 coupe/convertible trunk lid
Offline Coralsnake
Re: Interesting Inspector Paint OK Stamping
« Reply #1 on: July 22, 2021, 08:22:15 PM »
Here are some more from 1968 at the NJ assembly plant:
http://www.thecoralsnake.com/Inspectors
Several carry over, thanks for sharing
« Reply #2 on: July 22, 2021, 08:35:14 PM »
Thanks for sharing your discovery
Easy to see that you found a Metuchen example do you have any information on the car so that it can be labeled correctly for documenting. Didn't already have one from 69
Some examples from 68 and 70 NJ Mustangs
Most plants had a method to identify the inspectors and documenting who checked sub assembles or processes. Methods often included, numbers or names depending on production period. They also needed a tool (stamp, sticker...) or method for fill in personnel that would fill an inspector for vacation or sick purposes. Since Ford claimed that one out of every ten employees was an inspectors there were allot of them. Have been told that often the fill in man was often someone that use to fill that position (promoted) so that standards could be maintained.
Offline K-HESS
« Reply #3 on: July 23, 2021, 12:46:53 PM »
Jeff, I only have the trunk lid so I can't give you a vin number. The only other thing I can give you is the date stamping in the inner frame 8 23 C2
« Reply #4 on: July 23, 2021, 05:20:45 PM »
Thanks that will have to do.  Looks like it from, most likely, a very, very early 69 NJ car
Offline mtinkham
  • That'll be easy
« Reply #5 on: July 28, 2021, 01:52:25 PM »
CoralSnake...I just looked at your site with regard to Metuchen inspectors marks. The fourth picture down from the top, with two stampings, shows what appears to be a K that was marked on the apron extension possibly before paint. My April 67 Metuchen car has that same marking...is this a common marking for Metuchen?
