Author Topic: steering wheel to steering column gap  (Read 1445 times)
Offline fmr187
« on: July 19, 2021, 05:32:39 PM »
How much of a gap should there be between the steering wheel and the steering column? I put my steering wheel on and torqued it down and there is a 1/4 inch gap between the wheel and the column. Is this correct?
65 Convertible born in Dearborn on Feb 10
Offline fmr187
Re: steering wheel to steering column gap
« Reply #1 on: July 20, 2021, 04:42:38 PM »
Since no one had an answer for me I kept working at it. I found that a gap that big is not correct. With that big gap the horn spring loaded contacts in the steering column do no touch the metal rings in the steering wheel. As a result I had no horn. It was frustrating but I loosened the steering column and pulled it up to close the gap and lo and behold I now have a horn.
« Reply #2 on: July 20, 2021, 04:45:55 PM »
sounds like you found your answer. congrats!
Offline Scott302
« Reply #3 on: July 26, 2021, 05:58:11 PM »
Assembly manuals show the gap as .050"-.090"
Regards,
Scott
Scott Halseth
Ford Product Manager
National Parts Depot
MCA#01776
