Author Topic: Power steering ram bracket  (Read 1570 times)
Offline cob428
« on: July 15, 2021, 12:15:56 AM »
All the articles I searched,  it doesn't say what the finish is for the ps ram bracket. Is it a natural?
Concourse Wantabe
69 GT 500 Built Dearborn 06/69
A/C, Auto,
69 Mach 1 Metuchen 11/68
A/C, Auto 351 W
2009 Supersnake
Re: Power steering ram bracket
« Reply #1 on: July 15, 2021, 12:31:47 AM »
It is bare cast iron.
Offline cob428
« Reply #2 on: July 15, 2021, 09:12:17 AM »
Thanks again Bob.
Concourse Wantabe
A/C, Auto,
A/C, Auto 351 W
2009 Supersnake
« Reply #3 on: July 15, 2021, 01:44:37 PM »
Blasted natural will not give the correct appearance.  I usually like to dunk these for about 15-30 seconds in phosphate and soak in oil for 24 hrs.
« Reply #4 on: July 15, 2021, 03:55:39 PM »
How about more detail, like the type of phosphate, the percentages of the mix, temperature, oil type.
« Reply #5 on: July 15, 2021, 04:46:50 PM »
Another alternative is that after blasting you liberally coat them with Eagle 1 chrome wheel cleaner. Let the foam sit on the part for a couple minutes. The mild acid in the foam will change the appearance to some what closer to the appearance of fresh cast iron. After washing off dry with a towel dry .If you blow dry it will flash rust. I take a torch and heat up the metal to get the moisture out. After it cools I will coat with your go to rust inhibitor (T9 in my case). Not meant to be the ultimate answer but a quick and relatively easy process to get a closer look to original compared to out of the cabinet bead blasted.
