Author Topic: A/C Compressor Brushes  (Read 1885 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: February 19, 2011, 09:40:36 AM »
I just finished taking a repro set of Tecumseh Compressor brushes and replacing the generic mounting bracket with an OEM FoMoCo one.  I cleaned and clear-coated the bracket.  Then I used tubular brass rivets just like original, and borrowed my airplane mechanic's brake rivet setter.  Here's the results.
66 Metuch Conv
Nightmist, Std Blu Int
Re: A/C Compressor Brushes
« Reply #1 on: February 19, 2011, 11:20:37 AM »
Cool, I've thought about doing this before.  Can you supply the source for the rivets?
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: February 19, 2011, 11:24:45 AM »
Hanson Rivets
www.hansonrivet.com
Part Number  MS20450-C8-B17   Min. Qty. 200  $20.88 + shipping
If you need the setter, get it from any aviation tool company.
66 Metuch Conv
« Reply #3 on: February 19, 2011, 07:33:08 PM »
Thanks.  IIRC, the rivets are usually zinc plated.  Is there a particular reason you chose brass?
I have a hand rivet squeezer.
Offline bryancobb
  • 2009 Ridn' Around
« Reply #4 on: February 19, 2011, 11:30:11 PM »
I thought the zinc/steel ones would be harder than brass and thought I may break the phenolic pieces when crimping.
I think I have seen some originals with brass.
66 Metuch Conv
