Author Topic: How did the factory avoid paint chips  (Read 1055 times)
Offline PraireBronze
« on: July 08, 2021, 11:57:46 AM »
How did the factory avoid paint chips where painted items are butted up directly to other painted items?  I'm specifically wondering about headlight doors and quarter panel extensions (caps).  And on fastbacks, the vent louver assembly.
- Tim -
1965 Prairie Bronze 2+2 (under construction)
Build Oct '64 San Jose
289 4V Automatic Transmission (A-code clone :P )
Black Std Interior
AC, PS, Style Steels, 1" Drop, Konis
Aluminized 2 1/4 Exhaust, Tri-Ys
Re: How did the factory avoid paint chips
« Reply #1 on: July 08, 2021, 12:15:02 PM »
Keep in mind that factory paint was only about 3 mils and they were usually only applying paint where it was necessary.  Usually chips occur more easily from high paint/primer build up.
I'm sure they had a few boo-boo's here and there.
« Reply #2 on: July 08, 2021, 01:09:58 PM »
and remember the paint was baked.
Offline Dan Case
« Reply #3 on: July 09, 2021, 11:33:49 AM »
What Reply 1 and 2 said plus superior adhesion of everything from metal pretreatment to top coat. The most durable finish systems start with the best surface preparation and treatments.  There were factory production lines tests for adhesion and intercoat adhesion to verify finished systems met specifications.
Factories did have body repair staff at final assembly.
Dan
Offline mtinkham
  • That'll be easy
« Reply #4 on: July 09, 2021, 02:20:24 PM »
I thought they cut plastic washers from milk bottles...
« Reply #5 on: July 09, 2021, 03:54:18 PM »
That's a technique used with bolts in restoration to reduce "witness" marks (from the teeth on disc washers) while making adjustments, as in fender bolts. It works.
