Author Topic: Door Window Height Adjustment Bolts and Plate Finish - 70 NJ  (Read 1828 times)
Offline alanmac
My car has been painted twice, the 2 bolts and plate (on each door) for adjusting the rear height are body color. Looking through the unrestored pictures it appears they should have metallic finish.  The hardware spreadsheet description for the window / door hardware was unclear to me.  So are these parts zinc with clear chromate?  Alan
« Last Edit: July 02, 2021, 04:47:48 PM by J_Speegle »
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
Build Date: October 7, 1969
0T1190xx
Re: Door Window Height Adjustment Bolts and Plate Finish - 70 NJ
« Reply #1 on: July 02, 2021, 04:47:09 PM »
So took a look at the pictures I have where the finishes are visible. To start the plates IMHO were likely plated with possibly phosphate to protect against rusting by the supplier. This would also make a good base to paint over also. When I've found plates that were not painted body color they often appear (when not covered completely with rust) plated on one side and painted black on the other. Of course the worker could install them so that either surface was visible even though their was likely a finish that Ford wanted to be visible
In a survey of a small sampling its interesting that the cars with plates painted body color and those that were not formed a pattern suggesting the possibility of a running change on how Metuchen addressed the finish(s) on these plates
0T1125xx - Body Color
0T1129xx - Body Color
0T1127xx - Body Color
0T1210xx - Body Color
0T1245xx - Body Color
0T1263xx - Body Color
0T1285xx - Body Color
0T1292xx - Painted Black
0T1393xx - Rusty Finish but not Body color
0T1536xx - Dark Finish
0T1641xx - Dark/Black Finish
Earlier examples
Later examples
Retaining bolts throughout the year appear to be a zinc or cadmium finish
Offline alanmac
« Reply #2 on: July 02, 2021, 07:37:07 PM »
My car is 0T1190xx. Based on the consecutive build numbers you listed, my plates were likely body color.  I adjusted the height so some of the paint came off the bolts and it appears to be zinc plating underneath.
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
Offline alanmac
« Reply #3 on: July 04, 2021, 04:06:03 PM »
Does anyone have two spare 1/4 20 x .50, .75 dia disk washer 7/16 hex bolts?  They are zinc plated and have three dashes at 9,12 and 3 with NL in the center. Per the attachment,  disregard the black longer bolt on its side.
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
« Reply #4 on: July 04, 2021, 04:25:55 PM »
I may, but most of my hardware is identified by part number. Look in this Forum's Library under "Mustang Hardware Spreadsheet 69-70", the file by application (MHW69-70AP06.xlsx) for the number.
Offline alanmac
« Reply #5 on: July 04, 2021, 05:11:40 PM »
Cool,  I believe this is the P/N and description:
383049-S100   100   FF030   1/4-20X1/2,HH,REC,DISC LKW49/64,7/16HEX   SCREW,HEX,REC,DISC WASHER   4   WINDOW,DOOR,STOP BRACKET-DOOR@DOOR REAR
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
