Author Topic: Assembly line brake booster check valve  (Read 4377 times)
« on: June 26, 2021, 07:31:29 PM »
I am looking for a picture of a 1968 Midlands assembly line brake booster check valve. I have found some that were white and thought they were service parts.
Offline rnegless
Re: Assembly line brake booster check valve
« Reply #1 on: June 26, 2021, 07:52:01 PM »
this is a c7az in a bag the other is on my car (ha I see my hose is cracking)
68 San Jose 390 GT 4sp 3:25 Decor 12/29/67
« Reply #2 on: June 26, 2021, 09:25:22 PM »
They are white originally. Since the booster, master cylinder, spacer and check valve were all painted black originally - together - many believe the valves should be black, however on the assembly line they were painted.
Offline CT428CJ
« Reply #3 on: June 26, 2021, 10:13:31 PM »
The original cars that I have seen are black plastic like this.
« Last Edit: June 26, 2021, 10:15:35 PM by CT428CJ »
« Reply #4 on: June 26, 2021, 11:54:49 PM »
That is a typical 67 style SJ Midland check valve. The 68 Metuchen check valves are different shaped.
« Reply #5 on: June 27, 2021, 12:00:41 AM »
Your picture is more typical of the shape that the 68 Metuchen Midland check valve looks like. Notice the mold tang or what ever in the center of the check valve.
Offline CT428CJ
« Reply #6 on: June 27, 2021, 09:39:39 AM »
Quote
The original cars that I have the booster check valve photos of (about a half dozen) are February through July Dearborn cars.
Offline Coralsnake
« Reply #7 on: June 27, 2021, 10:03:15 AM »
There are two assembly line styles used in 68 NJ assembly. The first was white and it was painted black with the booster. The second type is black and has the word "Manifold" embossed on it. It is typically unpainted.
« Last Edit: June 27, 2021, 10:11:37 AM by Coralsnake »
Offline Coralsnake
« Reply #8 on: June 27, 2021, 10:07:06 AM »
The white painted valves are earlier and the black ones appear later in the year. I put the change over sometime around April
Early style (black paint is visible)
Later style
« Last Edit: June 27, 2021, 10:27:36 AM by Coralsnake »
« Reply #9 on: June 27, 2021, 12:28:57 PM »
+1 Bingo. Thank you for the pictures.
Offline rnegless
« Reply #10 on: June 27, 2021, 01:31:41 PM »
This is mine 35 years ago.
« Reply #11 on: June 27, 2021, 01:52:54 PM »
Thank you very much gentlemen, there is always something to learn in this hobby. Our car was built 02-12-67 so the white painted black it is.
Offline Keith Stem
« Reply #12 on: June 30, 2021, 10:58:27 PM »
Marty
My 4/29/68 Dearborn CJ booster valve was black, it was not painted. I know this because one day it came apart like a three dollar watch. All the pieces were black.
Keith
« Reply #13 on: June 30, 2021, 11:53:15 PM »
Looks like a candidate for another running changes to chase down
Offline CT428CJ
« Reply #14 on: July 01, 2021, 09:37:00 AM »
This picture is of an original Mustang assembled in Dearborn on Feb 16, 1968.
