Author Topic: What product to use: 1970 Mach tail light blackout and . . .  (Read 1577 times)
Offline ExportMach
rocker areas under the Mach molding. Jeff mentioned using a semi gloss black brush-on paint. Preferences? Success stories?
https://www.concoursmustang.com/forum/index.php?topic=656.msg103673#msg103673
Mark C
Offline ExportMach
Re: What product to use: 1970 Mach tail light blackout and . . .
« Reply #1 on: July 18, 2021, 01:21:54 PM »
What Im asking is what paint product has been tried by those who have re-applied the black out paint on the rockers and tail light panel? Thank you for your replies.
Mark C
« Reply #2 on: July 18, 2021, 04:20:41 PM »
I can't answer the question specifically since I've never owned or built a 70 Mach. One would think that that same or similar paint used for the pinch weld black out and other black out (such as headlight buckets in 69-70) would serve for this purpose.
Offline ExportMach
« Reply #3 on: July 20, 2021, 01:04:58 PM »
Thats my intention. Im trying to avoid using an incompatible paint over the urethane that has just been applied on the exterior. Im searching for a urethane blackout paint or maybe an enamel. Hopefully my research will not let me down.
I will report my choice and the results for the benefits of others.
Mark C
