Author Topic: Simple answer?  (Read 1087 times)
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
Simple answer?
« on: June 23, 2021, 03:05:46 AM »
On this clock, it had no original Knob in place, it made it simple to take apart and put in a new clock mechanism.  I bought a new Scott Drake knob and set screw. Well once installed the knob just slides on and off. Is it missing something?  Is this knob junk?  I looked and found no threads on the subject. Thanks for any help!
MCA#31064
Re: Simple answer?
« Reply #1 on: June 23, 2021, 08:33:18 AM »
There should be threads at the end of the shaft and a special screw holds the knob on. I can not tell for sure but it looks like the screw may be on the shaft.
« Last Edit: June 23, 2021, 08:35:30 AM by ruppstang »
Offline Armond
Re: Simple answer?
« Reply #2 on: June 23, 2021, 02:00:19 PM »
I put the knob on the shaft and screwed the set screw down and the knob just slid right off, like there is something missing.
MCA#31064
Re: Simple answer?
« Reply #3 on: June 23, 2021, 02:20:24 PM »
Nothing is missing, must be another bad reproduction part. The screw should not be able to slide through the knob.
Offline Armond
Re: Simple answer?
« Reply #4 on: June 23, 2021, 02:32:45 PM »
Ok thanks!  So this is a Scott drake part, does anyone know of a better knob?  Thanks!
MCA#31064
Offline Armond
Re: Simple answer?
« Reply #5 on: June 23, 2021, 03:48:01 PM »
I just bought an original knob off Ebay, we'll see how that goes.
MCA#31064
Re: Simple answer?
« Reply #6 on: June 23, 2021, 04:09:26 PM »
I would ask the source of where you bought this knob about why it does not work - strongly.
Offline Armond
Re: Simple answer?
« Reply #7 on: June 23, 2021, 08:53:27 PM »
I got it from NPD. so I will let them know. Thanks!
MCA#31064
Offline DragPack69
Re: Simple answer?
« Reply #8 on: July 06, 2021, 11:29:39 AM »
Armond, I had the same problem with mine.
I pulled out and held the rod (with padded angled needle nose pliers)  then installed the knob and set screw. tightened right up.
Offline Tiggie
Re: Simple answer?
« Reply #9 on: July 07, 2021, 08:45:04 AM »
I did this as well with the Scott Drake knob and is works great.
1968 8F01C191017, Built May 8, 1968
1994 GT, April 1994 Build
Offline Armond
Re: Simple answer?
« Reply #10 on: July 11, 2021, 03:38:17 AM »
I bought a nice used one and it worked great! After comparing them, the repo was flawed inside' Dumb........
MCA#31064
