Author Topic: Rear "grille" double face tape  (Read 2356 times)
Offline calypso
« on: June 16, 2021, 02:54:10 PM »
Anyone know of a supplier of the white thick double face foam tape used on the black "grille" pieces on the trunk lid and fender extensions?
Re: Rear "grille" double face tape
« Reply #1 on: June 16, 2021, 03:04:11 PM »
Original is typically described as thin relatively speaking . The last time I used some it was sourced at the paint auto body supply store.
« Reply #2 on: June 16, 2021, 04:50:27 PM »
Just have to find a roll wide enough so that you can cut a section from a single piece. Don't want to be able to look at the edge and see that its been pieced together.
Offline SCJSTU
« Reply #3 on: June 16, 2021, 05:09:36 PM »
There?s a Red 3M tape made for emblems, trim
Any auto store should have it
I used it on a loose front eyebrow on a 69 last year
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
« Reply #4 on: June 17, 2021, 02:14:40 AM »
Don't think they make it wide enough. Guess you could double it up but then the concern mentioned above may take place
« Reply #5 on: June 17, 2021, 11:25:00 AM »
You may try Shelby parts and restoration. In the past they sold a superior version of the rear deck grill mesh panel and may sell the tape for restoration purposes
Offline SCJSTU
« Reply #6 on: June 17, 2021, 12:36:26 PM »
BTW,
I need to replace mine...
whats the best way to remove old lace panels?........fishing line.....heat gun?
« Reply #7 on: July 05, 2021, 08:01:10 PM »
BTW,
Hopefully they are held on with the original material- old and aged :)
Any method that will not bend or curl the panels will be your best. Would start with dental floss or small fishing line with a nylon or plastic blade thing tool that will keep the adhesive from resticking after you have run the line or floss though the material. Clean up with silicon and wax remover has worked for me. You may choose another method but this is a method I use when removing emblems from new cars - debadging
Offline SCJSTU
« Reply #8 on: July 18, 2021, 07:42:48 PM »
Got the old ones off with a heat gun..,,,,,,,,,,word to the wise when putting the new ones on ( got mine from Branda ) they have the double sided tape already attached soooo come time to put on the long trunk piece 2 people recommended as once you place it  sticks and will not move.
I used painters tape to line up?..do two smaller end pieces first as not much room to move?.
