Author Topic: Cougar Taillight restoration  (Read 4301 times)
« on: June 15, 2021, 02:31:51 PM »
This topic crosses between 67 Cougars and the Shelby cars that used the taillight assembly.
Here I'm talking specifically about the cast taillight part.
Any restoration tips or gotchas?
Re: Cougar Taillight restoration
« Reply #1 on: June 15, 2021, 04:44:38 PM »
Ones I've done/used were always in good condition so don't have any specific hints.
I would think that the same "rules/guidelines" we associate with aluminum intakes and valve covers. Don't be aggressive during the cleaning process, don't add texture, especially in the the rear reflective surface. Maybe many of the suggestions as to cleaners and products that apply to intakes could be considered
« Reply #2 on: June 15, 2021, 08:12:11 PM »
The semi-gloss black around the outside of the housing is correct?
The PO LOVED semi-gloss black -- everywhere -- so just checking.
Offline rocket289k
« Reply #3 on: June 16, 2021, 01:32:55 PM »
Hi Bill,
Based on the unrestored 67 tail light I have - you are correct.  Semi-gloss black on the exterior housing.  I've attached a picture of that tail light for your reference.
Ron
« Reply #4 on: June 16, 2021, 02:49:27 PM »
Thanks Ron.
I carefully removed the cork gasket, which I assume is stock, rather than use the reproduction gasket. I do wonder if you can see it at all.
« Reply #5 on: June 16, 2021, 03:14:54 PM »
Thanks Ron.
You can't typically.
Offline rocket289k
« Reply #6 on: June 16, 2021, 03:35:31 PM »
You're welcome Bill and +1 to Bob's comment about the gasket.
Ron
« Reply #7 on: July 13, 2021, 08:09:26 PM »
Hopefully this is about what the as-cast look should be.
I also cleaned up all the grunge in the reflectors and chrome painted them. I'll use LEDs to keep the heat down.
I'm getting ready to tape off the rims for final semi-gloss.
« Reply #8 on: July 13, 2021, 08:54:23 PM »
Be sure to scuff up the chrome so the paint will stick.
« Reply #9 on: July 13, 2021, 09:53:52 PM »
Ah. But I chrome painted it, not plated it.
And only in the bulb area. Took a lot of tape.
