Author Topic: C6 TRANS SERVO  (Read 5556 times)
Offline cob428
Re: C6 TRANS SERVO
« Reply #30 on: June 23, 2021, 11:06:40 AM »
So if I am understanding correctly, this transmission code 9d142707 appears to be out of a pick up truck?
Concourse Wantabe
69 GT 500 Built Dearborn 06/69
A/C, Auto,
69 Mach 1 Metuchen 11/68
A/C, Auto 351 W
2009 Supersnake
Re: C6 TRANS SERVO
« Reply #31 on: June 23, 2021, 11:18:45 AM »
Dallas also built full size Ford and Mercury cars in that time period. So the case and the servo came from that plant originally. Likely some big transmission shop like AAMCO swapped it out and kept the original one as a core. Such things were common back in the 1970's when there were fewer varieties of transmissions those big shops could keep a rebuild ready to go on the shelf and swap transmissions while the customer waited.
If you wanted to use that VIN and pay $25 you could get a Marti report that would tell you exactly what it was when it was new.
Re: C6 TRANS SERVO
« Reply #32 on: June 23, 2021, 01:03:45 PM »
D is Dallas Texas - see here:
https://fordification.com/tech/VIN70.htm
I got my info at Wikipedia:
https://en.wikipedia.org/wiki/List_of_Ford_factories
It says that the Dallas plant closed in 1970, and the "D" is Ohio.
No matter how hard we try, the transmission is still not original.
Re: C6 TRANS SERVO
« Reply #33 on: June 23, 2021, 02:06:44 PM »
The trans is from a 1969 Ford something built at the Dallas plant. Of course, not original to a Mustang of any sort.
Offline cob428
Re: C6 TRANS SERVO
« Reply #34 on: June 23, 2021, 03:40:47 PM »
more so for knowledge than anything, just trying to decipher what I had and what I need to do.. Thanks for everyone's help.
Concourse Wantabe
A/C, Auto,
A/C, Auto 351 W
2009 Supersnake
Offline jmlay
Re: C6 TRANS SERVO
« Reply #35 on: July 14, 2021, 02:05:44 PM »
Interesting reading on the case machining as related to the  R servo
https://www.fordfe.com/c6-upgrades-t164070.html
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Re: C6 TRANS SERVO
« Reply #36 on: July 14, 2021, 05:42:25 PM »
Lots of good information and pictures on that link. I can confirm the part about the machined step in earlier cases. I wish I could tell you when Ford started machining all the cases without that step.
