Author Topic: Vintage Burgudy Paint Formula  (Read 1190 times)
Offline 65,66,67UNRESTORED
« on: June 07, 2021, 01:54:20 PM »
Does anyone have an accurate basecoat match for code X Vintage Burgundy ?
65 Fastback unrestored survivor Ivy Green, Black Interior, C code, 4speed, A/C
65 K Fastback unrestored survivor Ivy Green, Palomino Interior
65 Coupe unrestored Caspian Blue, White Vinyl Top, Blue Interior, K code
66 Convertible unrestored survivor Raven Black, Red Deluxe Interior, C code, A/C
Offline Hipo giddyup
Re: Vintage Burgudy Paint Formula
« Reply #1 on: June 07, 2021, 02:07:45 PM »
I don't believe that the code "X "would have changed between 65 and 66? I just painted my 66 vintage burgundy coupe a few years ago. Attached is a picture of the PPG label if you go that route. Even though it says Chrysler, I was told by the paint supplier that companies can "purchase" the specs for the mixes?For example, Mack truck has  the color match specs for Ford's Wimbledon white. At least this is what the paint guys have told me? Hope this helps.
Regards Bill
« Reply #2 on: June 07, 2021, 04:04:42 PM »
Hi Bill,
 Thank You for replying. PPG actually has a formula for Ford code X, Vintage Burgundy and their mix number is 50657. The problem is paints of yesterday used lead which has been removed and now the color is changed. I'm trying to get a very accurate match to the original color. Jeff
« Reply #3 on: June 07, 2021, 04:59:09 PM »
Your best bet would be take an unrestored part, maybe the back side of a headlight bucket, or a chip from under the windshield molding (pinch weld area) to see if they can color match. Probably your best bet with what you are explaining.
And it looks like they did change Vintage Burgundy between 65 and 66, two different codes.  Nothing is easy..
« Last Edit: June 07, 2021, 05:04:53 PM by Hipo giddyup »
« Reply #4 on: June 07, 2021, 06:57:31 PM »
My reference material says Dupont 4490 for both years, and 1967.
Offline aaatp
« Reply #5 on: June 07, 2021, 08:05:25 PM »
Pretty much the same here, I am very pleased with the color match to the original color
« Reply #6 on: June 07, 2021, 08:09:38 PM »
 For PPG they show 50657 for 65', and 50669 for 66'. I bet it is hard to tell the difference side by side. ::)
« Reply #7 on: June 08, 2021, 02:42:34 PM »
Look in this Forum's library in the Ford Car Parts (aka MPC) paint section, page 8, for paint code X, 65 thru 67 are the same, Ford M1J 1632; and page 12, Ford CC66AZ-19500-D. Note: It's called "Maroon Metallic".
