Author Topic: 70 fixed antenna  (Read 506 times)
70 fixed antenna
« on: June 01, 2021, 08:38:17 AM »
Pulled this antenna off a 70 fender in long time storage.  It is of fixed length, so it appears to not be correct according to the reference document linked below.
It is listed as a Ford part, and it does have the correct spacer.  Other than a later service part, any ideas what the correct application is for this?
http://anghelrestorations.com/uploads/3/1/7/6/3176630/antennas_v1.1.pdf
Re: 70 fixed antenna
« Reply #1 on: June 01, 2021, 09:36:32 AM »
Looks like someone pressed a replacement antenna tube in an original ford mounting base after original 3 piece was broken off .  There is an id # stamped on bottom of the cast mounting plate
