Author Topic: 1970 Quarter window upper grommets  (Read 635 times)
Offline alanmac
« on: May 24, 2021, 01:01:11 PM »
My upper quarter windows are loose. I think there must be a plastic grommet for the post in the upper window frame that are deteriorated.  I could wrap tape on the post but is there a better fix? Is there an aftermarket grommet available?  Alan
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
Build Date: October 7, 1969
0T1190xx
Offline alanmac
Re: 1970 Quarter window upper grommets
« Reply #1 on: May 25, 2021, 01:48:09 PM »
Both grommets are missing.  Probably lost like other small retainers, that are missing after the paint / body work.  I am going to buy a 5/16 solid plastic rod and make a set.
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
Offline RocketScientist
« Reply #2 on: May 26, 2021, 02:33:47 AM »
I used hard teflon tubing that is used for instrument air-lines but any hard plastic tubing will do. As you need so little of it, a good hunt around the house and garage will turn up something that works.
Brad
Offline alanmac
« Reply #3 on: May 26, 2021, 12:35:19 PM »
 Updated. Thanks for the input.  I found that a 7/16 OD x 1/4 ID vinyl tube cut to ~ 1/2 in length with one layer of gorilla tape around the outside of the tube is a really good fix.  The quarter window doesn't move in or out but a few thousands of an inch.   Alan
« Last Edit: July 01, 2021, 06:21:21 PM by alanmac »
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
