Author Topic: Dearborn FMX transmission numbers  (Read 829 times)
Offline BlackMcode1970mach1
« on: May 17, 2021, 09:32:37 PM »
                 In the process of cleaning up my fmx for my 70 mach  1  I noticed  what looked to be a 29 or a 19  on top of the cast iron housing. To me that  is what it looked like . I have no build sheet for my car at all. Its a dearborn car if that matters. Mark
« Last Edit: May 18, 2021, 06:10:18 PM by J_Speegle »
Offline Mike_B_SVT
Re: transmission numbers
« Reply #1 on: May 17, 2021, 10:26:48 PM »
You should have a VIN stamp on it somewhere.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
« Reply #2 on: May 17, 2021, 10:44:23 PM »
I have that  and the tag , im refering to the assembly line markings in yellow marker or what ever they used. Maybe i didnt explain myself well. sorry this came out of a donor car that i took apart my car is originally a fmx car but they put a 4 speed in it. Mark
Re: Dearborn FMX transmission numbers
« Reply #3 on: May 18, 2021, 06:13:52 PM »
Numbers likely varied and were related to assembler or inspector numbers applied through the transmission assembly process. Other numbers that could be applied would relate to car assembly plants and not applied at all of them.
Have examples of a number of applications showing letters also applied with paint or maker in different colors
Automatic transmissions are one of the more difficult items to collect markings from since they were so often rebuilt and rattle canned as part of the process
« Reply #4 on: May 18, 2021, 11:59:37 PM »
ok- understandable lots of variables . I beleive its a 29  who knows what that could mean . thanks
Offline 69GT350H
« Reply #5 on: May 19, 2021, 10:01:03 AM »
On my Dearborn 69, I have what might be a hand written "87" in yellow, and an "E" in orange. You can also see a yellow fat "O" and a green daub on the front pump.
« Reply #6 on: May 22, 2021, 08:03:24 PM »
Thats interesting i should correct myself here . The FMXtransmission came out of a clunker mach  that was badly rusted.If you look close you can see a 29  .  Im not sure what plant it was built at i have the buck tag yet . It was a white mach 1 2v cleveland with tach dash and a shaker . I had to snatch it up for a good parts  car. Mark
« Last Edit: May 22, 2021, 08:13:37 PM by BlackMcode1970mach1 »
