Author Topic: Passenger Door Glass adjustment  (Read 464 times)
Offline Colorado56
« on: May 17, 2021, 02:55:04 AM »
Reinstalling my door glass in my 68 fastback and have run into a problem.  Drivers side went back together perfectly but the passenger side not so much. The passenger side door glass comes in contact with the upper rear corner of the drip molding. I have tried many adjustments and can not seem to get it right. Door hinges have new pins and bushings installed as well.  Always had issues with coupe/convertible front to rear window alignment but never had an issue with fastbacks. Has anyone else had this issue and a solution to resolving it?
Dave
Re: Passenger Door Glass adjustment
« Reply #1 on: May 17, 2021, 09:12:33 AM »
I had this problem on a 67 fastback and it was the passenger side as well. I think some cars were made a bit out of jig because this car had not been in a collision. Not the best solution but I moved the door ahead just enough to get the window to clear with adjusted as far forward as possible. If there is a better solution I would like to know too.
Offline Colorado56
« Reply #2 on: May 17, 2021, 11:23:58 PM »
Thanks for the idea. Not sure what I am going to do.
