Author Topic: Upper Control Arms  (Read 3349 times)
Offline KDunne
Upper Control Arms
« on: February 13, 2011, 05:57:58 PM »
Hello
I have a set of original 68 upper control arms.  Unfortunatley, they have been phosphated.  Can anyone tell me the easiest way to remove the phosphate coating?
Re: Upper Control Arms
« Reply #1 on: February 13, 2011, 08:36:17 PM »
Glass bead will take it right off.
Offline TLea
« Reply #2 on: February 13, 2011, 11:02:55 PM »
I think his dilema is in addition to being phosphated they have also already had new ball joints riveted in
Offline KDunne
« Reply #3 on: February 13, 2011, 11:22:23 PM »
Yes Tim is correct.....
« Reply #4 on: February 13, 2011, 11:44:25 PM »
If the zinc phosphate is that pronounced and you want to get rid of it you could use the spray on acid product Eagle One "Wire Wheel Cleaner" and it will dissolve the zinc phosphate . Work it with a rag. If you use fine steel wool it will start to heat up because of the chemical reaction.   The tricky part is you will have to duct tape or similar liquid proof tape off the plated boot retainer plate as the acid in the wire wheel cleaner will attack that plating as well. After you get the zinc phosphate dissolved I would go over it with a regular wheel cleaner to neutralize the acid and then wipe it down and towel it off dry. You can use water as a alternative to neutralize the acid but you must towel dry rather quickly. If you blow dry it will slightly flash rust and leave a slight orange hue from the rust. You must then treat it with Boe shield or the like for rust prevention. I hope this helps. Bob
« Reply #5 on: February 14, 2011, 01:20:34 AM »
Yikes, sorry about that.  Bob's method should work great.
Offline KDunne
« Reply #6 on: February 14, 2011, 08:40:24 AM »
Hi
Thank you for the excellent responses.........I will report back on how this works.
Thank you
Kevin
Offline 68 S Code
« Reply #7 on: February 14, 2011, 12:34:41 PM »
Not sure about phosphate but i know a diluted mixture of muratic acid and water will strip plating like zinc and zinc dichromate off bolts and brackets. Then just rinse with water. Its readily available at a hardware store so you can try it on some phoshated bolts as a test and if it works then go for it.
Offline RocketScientist
« Reply #8 on: February 15, 2011, 08:44:27 PM »
My view is why would you want to remove the phosphate coating as it is a reasonably good anti-corrosion coating anyway? The only reason why you would want to do so is if the phosphate coating has broken down and there is rust or corrosion on the part. If the phosphate coating is good then I would detail the part using a primer and then some good paint.
If you strip the phosphate coating the part will have to be repainted anyway as it will begin to look untidy in a very short time. Natural parts are great, I have a lot of the on my car but the six weeks worth of re-detailing parts every year gets a bit tedious after a while.
Cheers, Brad.
« Reply #9 on: February 15, 2011, 10:10:12 PM »
I'm guessing he wants to remove the phosphate coating since it is an incorrect finish on control arms.
Offline KDunne
« Reply #10 on: February 15, 2011, 11:22:06 PM »
Correct...I realize that the phosphate will look better over time,  but I would like the finish to be correct.  Again,thank you to all for your inut and suggestions
Kevin
