Author Topic: acorn nuts for hood moulding  (Read 2758 times)
Offline BlackMcode1970mach1
« on: May 10, 2021, 08:21:36 PM »
hello ! Anyone point me in the right direction for the correct hardware to secure the hood moulding to my hood? The one i have are acorn type nuts . none of them are reusable   Mark
Re: acorn nuts for hood moulding
« Reply #1 on: May 10, 2021, 10:35:37 PM »
Here was the discussion from last year. -
Search results for: hood moulding
https://www.concoursmustang.com/forum/index.php?topic=23514.0
Hardware stores use to carry acorn nuts but have not checked that resource in a number of years
« Reply #2 on: May 10, 2021, 11:15:49 PM »
Not exact but close ?   AMK B-12943    https://www.amkproducts.com/wp-content/uploads/2019/09/JR.jpg
« Reply #3 on: May 11, 2021, 01:35:30 AM »
Thanks guys ! Brian those look like they are close  I will order some and the clips to .I didnt think to check hardware store.  Btw  the strip on front of hood that is riveted on was that assembled after care was painted? Mine was panted  over in a repaint so im guessing they were added after  car was opainted or were they on car when it was painted? Mark
Offline sah62
« Reply #4 on: May 11, 2021, 11:19:40 AM »
The semi-gloss black bracket was attached using 1/8" pop rivets AFTER the car was painted.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
« Reply #5 on: May 11, 2021, 12:54:28 PM »
Close? The stud is a size 8, the replacement, AMK B-12943 is a 10-24. Sure, it will fit - very loose.
See if AMK has their Hood Molding Kit, F-142 in stock. It does not show up on their web side, but is in their paper catalog. It's appears to be the correct one, and includes the rivets.
(I'm "leery" about AMK kits as they don't list the the contents' part numbers.)
« Reply #6 on: May 11, 2021, 08:32:28 PM »
I looked on their website it says  kit number F142 if iam reading it right. I will call in am  to check it out.  Now if there was a  complete kit for the cladding ! :) ;) Thanks to all for helping me. Mark
« Reply #7 on: May 13, 2021, 06:44:31 PM »
no such luck on attatching  hardware to hood moulding as they dont make it anymore i was told. Mark
Offline sah62
« Reply #8 on: May 17, 2021, 05:40:46 PM »
I found these with a little searching: https://www.topflightautomotive.com/products/corvette-america-1978-1982-chevrolet-corvette-seat-hinge-cover-acorn-nuts-12-piece/
The color looks wrong and there's no mention of the size, but they're the right style.
Scott Hollenbeck
« Reply #9 on: May 17, 2021, 09:37:18 PM »
I did find some of those acorn nuts at a hardware store near me.     they were silver to .I would have to find the other half that goes inside of the moulding . I  was with wife at the time so that was taking up precious time lol  Only other thing would find  a nos hood molding that might have attaching parts with it. That would be pricey indeed. :-\Mark
« Reply #10 on: May 17, 2021, 09:47:38 PM »
The only one i have  Mark
« Reply #11 on: May 18, 2021, 01:04:25 AM »
PM sent.
Offline alanmac
« Reply #12 on: May 18, 2021, 03:00:14 PM »
My Mach 1 was built early and has these acorn nuts retaining the hood molding.  AMK-F1196.
« Last Edit: May 18, 2021, 03:07:20 PM by alanmac »
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
Build Date: October 7, 1969
0T1190xx
« Reply #13 on: May 18, 2021, 04:07:05 PM »
The 70 Mustang Body Assembly Manual (AM0031 [pg 49) specifies 45277-S36 for the taillight panel. I assume that's what is in the AMK kit (my previous stand, you really don't know what you are getting in their kits). The hood molding is 384102-S100 (Same book, pg 25) but the two nuts are different. The only things that are the same is the thread, 8-32, and name, acorn nut. They will work, but -
Offline alanmac
« Reply #14 on: May 18, 2021, 08:07:31 PM »
Jim, Too bad AMK doesn't have hardware descriptions.  Unknown is when did each assembly plant run out of the 69 hood trim acorn nuts 45277-S36.  What is finish S100?
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
