Author Topic: Heater assembly-to-cowl vent attaching hardware  (Read 1119 times)
Offline mtinkham
  • That'll be easy
« on: April 29, 2021, 01:24:58 PM »
I am looking for a picture, if available, of the fastener that attaches the heater assembly to the cowl vent on a 1967 non-ac application (see attached picture - bracket circled). It is for my signature car.
I have searched for "heater" and pictures are limited of this area.
I have looked at Jim's excellent hardware spread sheet and I believe the following are the correct fastener, but wanted to confirm with a picture, if possible.
42159-S8   8   FF149   14-10X1 1/4HEX,REC,FLNG 1/2,3/8HEX,TPG   SCREW,HEX,REC,FLNG,TPG   1   HEATER-DASH@DASH UNDER RH DASH
45149-S2   2   FF209   14-10NUT,SPRING,0.910L,0.560W,0.087PNL,RECT,J   NUT,SPRING,RECT CORNER,J   1   HEATER-DASH@DASH UNDER RH DASH
Thank you.
Re: Heater assembly-to-cowl vent attaching hardware
« Reply #1 on: April 29, 2021, 07:49:56 PM »
If we assume your factory used the same bolt as SJ, then this applies.
I think. It was in my interior stuff to plate and was not marked. But all the dimensions and type are correct.
There is no head mark.
I can't find the spring nut at the moment, but it's pretty standard stuff.
« Reply #2 on: April 29, 2021, 08:22:53 PM »
Don't have any NJ examples we can use for this question. Sorry
« Reply #3 on: April 29, 2021, 08:43:18 PM »
The spring nut should look similar to this.
I assume you are parts hunting in your stash but forgot what this all looks like?
Offline mtinkham
  • That'll be easy
« Reply #4 on: April 30, 2021, 01:34:51 PM »
Thank you BossBill...this heater assembly was removed almost 20 years ago...I've got a bag of hardware labeled bag-o-stuff - Interior. Quite embarrassing, actually.
« Reply #5 on: April 30, 2021, 02:15:20 PM »
Thank for the compliment. There are two sources listed in the spreadsheet, the source for the hardware item itself - in most cases a picture is included in that source - and the source for it's application (aka where its use is). As in any large spreadsheet (there are about 10,500 items listed in the master file, and I can't tell you how many columns wide it is), abbreviations are needed so there is an accompanying explanation. Remember, a "picture" is after the fact, many decades after in fact (pun intended). In most cases, it confirms what was done.
« Reply #6 on: April 30, 2021, 02:45:54 PM »
Shot a pic of what you find in your bag-o-stuff as we're curious.
« Reply #7 on: April 30, 2021, 02:57:45 PM »
Thank you.
You need the AMK guide to fasteners book. NPD sells it It will decipher the fastener code and show a picture. When looked up in the book the number has a page reference . When you go to the page reference there will be a picture .The picture will be of the type of fastener but not necessarily with the correct marking. Especially helpful if you have a pile of fasteners that you know came from the car and you want to figure out what is what.
« Last Edit: April 30, 2021, 03:00:28 PM by Bob Gaines »
« Reply #8 on: April 30, 2021, 03:48:39 PM »
Bingo!
Also: "Ford Standard and Utility Parts Catalog", available for 1965, 1966 and 1969 are excellent additional sources. Available from most Mustang parts sellers.
Offline mtinkham
  • That'll be easy
« Reply #9 on: May 04, 2021, 01:39:27 PM »
Thank you all for the information.
Mark
